The MP3car.com Store
Thread Tools Search this Thread Display Modes
Old 06-08-2006, 08:41 PM   #16
pancit175's CarPC Specs
Vehicle: 96 Talon
My Photos: (0)
Quote: Originally Posted by Red GTi VR6
I am running optical
Ditto, Optical Rocks!!! I just started running optical in my car after I stopped getting lazy and finaly shelled out the cash to do it. Probably the best investment in my system to date. So no ground noise, no static/noise from the computers systems (i.e. mouse/touchscreen)
" In the beginners mind there are many possibilities, but in the experts mind there are few. "- Shunryu Suzuki
PROGRESS:
[DONE&DONE] (Considering a redesign)
pancit175 is online now   Reply With Quote
Sponsored Links
Old 06-08-2006, 08:52 PM   #17
_
RedGTiVR6's CarPC Specs
Vehicle: VW GTi VR6 / Ducati 900 SS & S4R / Dakota R/T Supercharged
My Photos: (90)
Quote: Originally Posted by mick0uziel
i also had the same case, with my first carputer, a ground loop isolator and the monster cable worked to eliminate it. now that i built my 2nd carputer, its there again, i put in a ground loop isolator combined with a power noise eliminator but still whines. i bet its the rca cable i used. i should have used monster to begin with, now its costing me twice the money and effort, im gonna order the monster 302xln about $50 5meters long. i bet this would take out the whining.
PLEASE let us know if it fixes it
Jan Bennett
PLEASE do NOT PM/Email/IM me asking me to spoon feed you. Please post on the forums! Chances are, someone else has or will have the same questions.
RedGTiVR6 is offline   Reply With Quote
Old 06-08-2006, 08:53 PM   #18
_
My Photos: (90)
precisely
it just never made sense to me to skimp on this stuff, because you ALWAYS end up redoing it and spending more money by tossing your crappy stuff to only replace it with what you should have bought in the first place....lol
Jan Bennett
Old 06-08-2006, 09:19 PM   #19
Vehicle: 96 Talon
My Photos: (0)
I'm lucky that i only had to add it on to my existing setup and the fact that i get mad discount on the wires esp the optical lines
PROGRESS:
Old 06-08-2006, 09:39 PM   #20
_
My Photos: (90)
yeah - the discounts helps out a great deal....I would have these $200/each rcas without it...lol
Jan Bennett
Sponsored Links
Old 06-08-2006, 11:29 PM   #21
mick0uziel's Avatar
Vehicle: 98 honda civic
My Photos: (0)
yeh my advice is to get the good stuff only, especially the monitor and audio cables. i was going to order this
http://www.monstercables.com/productPage.asp?pin=176
it will arrive next week. so keep my fingers crossed.
7" Lilliput
Opus 150
mini itx 1Ghz
1GB sdram
97 Prelude
mick0uziel is offline   Reply With Quote
Old 06-09-2006, 01:31 AM   #22
Fusion Brain Creator
2k1Toaster's CarPC Specs
2k1Toaster's Avatar
Vehicle: 2001 Honda Civic EX Coupe
My Photos: (1)
Same as the whine from speakers, or whine from alternator?
Old 02-21-2007, 06:53 AM   #23
Gamer64's CarPC Specs
Gamer64's Avatar
Vehicle: 1998/Opel/Omega 2.5L V6 24V
My Photos: (1)
RedGTI: Does your amp have an optical in? Or do you have an Optical 2 RCA converter? Cause my mobo (Commell LV-677) has an optical out.
If you`re not first, you`re last !
Gamer64 is offline   Reply With Quote
Old 02-21-2007, 07:01 AM   #24
_
My Photos: (90)
No optical ins....I use the Alpine 701 processor.
Optical out of PC -> Optical In Alpine 701 -> Analogue out to amplifiers
Jan Bennett
Old 02-21-2007, 08:49 AM   #25
My Photos: (0)
This is a VERY common problem in car audio equipment and it usually has nothing to do with the audio end. It's the equipement end. But before you read any of this thread concider your audio lines (be it wire or optic). Where are they running in relation to your power lines? Granted, this is only a potential sollution to those who are having sound issues in the car and not under the hood. At any rate, AC power will distort audio signals where the two lines run parrallel to each other so make sure you've got a good couple of inches between the two.
The more elecrical equipement you add to a car the more strain you put on the alternators' ability to power everything. Anyone who is having this issue needs to add up the amps you're drawing from all of your electronics and then compare it with how many amps your alternator is pushing. A typical output for an alternator is around 90 to 110 amps and a car will draw that much on it's own with all the factory installed equipement turned on...add a PC and a sound system and you're likely tanking the alternator.
If you've already taken the liberty of upgrading your alternator, or you've got a higher powered one in the first place (i.e. a truck or SUV), then the next step is to upgrade ALL the grounding. Grounding to the alternator, grounding to the battery, and by all means grounding to your equipment. Grounding for any given piece of equipment should probably be bigger (though the same ga. will be work) in gauge than its power line. AND DEFFINATLY, it should never share the same grounding point as another piece of equipment. You should also concider braided grounding belts as opposed to wires to allow more AC curent flow.
If you're still having issues after all that then concider upgrading your battery to a deep cell core...expensive to be sure but well worth it. They'll act more like capacitors in the event you have a power surge...which also tank your alternator.
All that from a newbie....hope it helps yall.
cbevis is offline   Reply With Quote
Old 06-29-2007, 02:36 AM   #26
AznRida's CarPC Specs
Location: Saint Petersburg, FL & Flint, MI & Auburn, NY
Vehicle: 1996/Honda/Accord
My Photos: (0)
In all honestly if you can't find a solution the best way to go is a very annoying way. Have everything set up and turned on. wire your RCA wire section by section until you hear the alternator whine and when you hear it search within a foot of the strongest whine signal. I had to do this on my friends car when installing his amps because someone had previous wired unnecessary equipment into the car and their wiring was that of a walrus trying to fingerpaint. You may need another person to rev the engine or to help find it. It's tedious but it helps when you have tried everything else....
AznRida is offline   Reply With Quote
Sponsored Links
Search this Thread:
Advanced Search
Trackbacks are Off
99 Acura TL carputer project pics Darkshear Show off your project 15 08-23-2007 12:14 AM
Carputer wont power up once Amp is installed Legrath Newbie 6 03-20-2007 10:16 PM
My 2006 Scion xB (portable) Carputer setup! w/pics! breaker021 Show off your project 26 01-05-2007 09:34 AM
sound quality between carputer going through the HU and carputer going to amp lookinco Car Audio 9 08-07-2005 11:27 AM
carputer install: I dare you... Cat Monkey General MP3Car Discussion 42 01-27-2005 05:34 PM
Sponsored Links
Ad Management by RedTyger
