Old 03-16-2006, 02:15 PM   #1
michaelrj9's Avatar
using speaker wire as power wire
just was wondering if it would be ok use 12-14 ga speaker wire for low power accessories or is it a big "NO NO"...like for a 7" monitor or slot load dvd etc..
I was just wondering because it seems like it is hard to find good quality 12-14 ga power wire (lots of thin strands) seems like they all are very course..and there is lots of good quality speaker wire that gauge..Very flexable Plus all you have 1 wire to mess with.
If not what is the reason that you should'nt.
Is the wire or insulation any different between speaker wire & power wire?
Just was wondring.....
michaelrj9 is offline   Reply With Quote
Old 03-16-2006, 02:38 PM   #2
MySQL Error
MatrixPC's Avatar
Why not?
7" monitor and dvd doesn't require lot of current.
Y2K Accord Dell GX150
EmoRebellion is a SCAMMER
MatrixPC is offline   Reply With Quote
Old 03-16-2006, 02:58 PM   #3
rcdash's Avatar
At 12-14V, insulation is not an issue - the gauge and current draw will determine how much the wire heats up.
For little stuff, that gauge is probably overkill - will work fine.
rcdash is offline   Reply With Quote
Old 03-16-2006, 03:35 PM   #4
Speaker wire is a good solution when you need to run both hot and gnd together. Wish I would of thought of that.
BTW, I have found the best place to buy wire and wire connectors is home depot
EricE is offline   Reply With Quote
Old 03-16-2006, 04:00 PM   #5
i use a 100m roll of speaker wire i purchased a coupke of years ago, i use it for everything!
jammy-dodger is offline   Reply With Quote
Old 03-18-2006, 01:49 AM   #6
Banned
xdjxklusivex's Avatar
i used speaker wire to wire up **** on my bike :-)
xdjxklusivex is offline   Reply With Quote
Old 03-18-2006, 04:08 AM   #7
ramy_zohair's Avatar
i'm going to do the same thing for my screen & backup cam.
Final Touches
Car: 2002 Mitsubishi Magna EI
CarPC: SP13000, M2-ATX, 512 MB RAM, 120 GB 2.5" HD, X-Fi Sound Card, Xenarc 700TSV, Garmin 18 USB.
Audio: 2X15" Rockford Punch Z, 1 Rockford Punch 2-ch Amp, 1 Soundstream Lil Wonder II 4-ch Amp
ramy_zohair is offline   Reply With Quote
Need help: Where to drill hole in Yukon firewall for power wire? Eric Q. Power Supplies 2 06-29-2005 09:28 AM
Opus wont power, green wire has constant 5v??? jedi7001 Power Supplies 3 02-22-2005 10:30 AM
DC-DC Car Power for Mac Mini MikeH MacCar 53 02-19-2005 12:13 PM
Power WIre through firewall Murphy3603 Power Supplies 14 10-27-2004 12:18 PM
Ignition Power Wire Location djXternal General Hardware Discussion 8 08-11-2004 06:08 PM
