03-30-2006, 03:01 PM
#46
MySQL Error
well...i'm doing a lot more research again. i have to make sure that i can get a software x-over as well, since my amps dont have x-overs. UGH.... i have a ton of emails going out. I may just end up keeping the alpine and going unbalanced into the amps (i would hack up the face plate so i could hide everthing but the volume knob)....id rather avoid this though.
anyways, quack, i may have an m-audio soundcard for sale...it has balanced 4 volt outs :-) you can make a cable to convert it to unbalanced 4 volts for your amps if needed.
New System in progress:
M10k
Phaze TD1500 ~> Seas g18rnx/p
Zapco Ref 500.1 ~ 12" tc-9
Transflective Xenarc
My Car Pc Install
03-30-2006, 03:58 PM
#47
_
if you hack up that alpine deffinately let me know!
03-30-2006, 05:23 PM
#48
MySQL Error
well emu just emailed me back and they dont have x-over ability in there soundcards! ARGH!!!! there is another problem with going 'pxa'-less.
M10k
My Car Pc Install
03-30-2006, 05:39 PM
#49
_
man - if we had the means and the money, we should design a high quality all in one solution to this problem!
03-30-2006, 05:41 PM
#50
MySQL Error
well...i can't help with the means...probablly not much with the money (relatively) BUT i can provide the problem....wait...
M10k
My Car Pc Install
03-30-2006, 06:21 PM
#51
an all in one solution would be a double din head unit that is a pc designed especially for cars. It's sound card would be equivalent to a H701 and it would have rca outs that go to the amps. The sound card would be like an equalizer and there would be a remote to control those settings and to tune the sub level. There would be a slot load dvd-rw drive and four usb ports on the front...this would be an all in one solution.
PostCount++
- SrCsTc's Bezel
- Alpine W200/H701
- ED Nine.2X
- OZ Matrix Elites
- ED Nine.1
- Idmax 12's
03-30-2006, 07:54 PM
#52
_
heh - so who wants to help design this bad boy??
03-30-2006, 07:57 PM
#53
MySQL Error
Not It!
M10k
My Car Pc Install
03-30-2006, 08:56 PM
#54
doesn't sound too hard. Get an P3 1ghz sbc, an MP3+, a USB hub, a griffen power mate (to control the levels on everything and cycle through) and LCD form a nite-max (to be the interface), and a programmer and you got yourself a maybe a 1-1.5 din solution with a software based eq.
Carputer Progress: Here we go again...
THE GF THEME
Genesis has speed
Genesis has class
Genesis sent money
before your a__;)
Join the fight against carputters. EMAIL ME!
03-30-2006, 09:24 PM
#55
MySQL Error
with crappy pre-out voltage and noise
M10k
My Car Pc Install
03-30-2006, 09:55 PM
#56
_
Genesis - I don't think you've gotten the whole point to this thread....lol
03-31-2006, 03:30 AM
#57
MySQL Error
oooooo....i think i may have something.... stay tuned, i dont want t clutter up then thread with more links or products until i know for sure.
M10k
My Car Pc Install
03-31-2006, 07:43 AM
#58
_
tease
03-31-2006, 12:32 PM
#59
All of the ideas that i presented have been done already. Many people are currently using double din computers, but the part that's missing is the H701 audio equivalence factor. The computer needs to be designed as a head unit with a remote that has sound menu options that pop up over windows (much as a monitor's options menu would pop up over whatever is in the background). The RCA's should have at least 4V with an optional optical out. The carputer should also have it's power supply integrated much as a standard headunit so that standardized connections can be used when replacing a stock headunit. The computer should be developed to ensure instantaneous boot times and the front end should be linked to the sound card controllability.
Those are my requirements...now develop!....lol
PostCount++
- SrCsTc's Bezel
- Alpine W200/H701
- ED Nine.2X
- OZ Matrix Elites
- ED Nine.1
- Idmax 12's
03-31-2006, 02:12 PM
#60
Interesting links
I noticed most of the software EQ options are plug-ins...usually compliant with a standard called VST (Virtual Studio Technology). Sorry if this is common knowledge...it wasn't for me so I did a little research. Here are a few links of interest:
- Wikipedia page on VST - explains a lot
- Audacity - an open source VST host capable of accepting a plug-in
- Muse Research's Receptor - a piece of hardware that accepts VST plug-ins. Thought this was interesting because it shows that people are trying to do the exact opposite of us...process the sound off the computer. Might be controllable from the PC and would take on all the processing load.
| Thread Tools |
| Display Modes |
Linear Mode
