04-02-2006, 11:21 AM
#91
_
Quote: Originally Posted by Genesisfactor
i'm curious though, if we get a quaility line driver with the m-audio or whatever, and use a software eq (total cost seems to be about $700 for those to together), why in the world would a mom all in one solution cost more than $2-$3K???
Also scott, way cool job man!
a line driver IMO isn't a high end solution.
04-02-2006, 11:24 AM
#92
_
Quote: Originally Posted by scott_fx
4) they run off of ac and it's not just a simple transformer inside that would could bypss with a dc psu.
Actually, there are a few people who have converted these to DC and are currently running them in their cars and competing rather successfully with them.
I'm speaking of the Drive Rack specifically.
Quote:
So there you have it... i think hardware wise we are getting close. keep in mind these boards have only two outputs so with most of us, we'll need 2 boards...getting us the $300 mark...not too shabby
this just doesn't settle well with me. It might work fine for others, but the fact that you have to purchase multiple units, bothers me...more components = more possibility for problems and interference.
btw - what is this guys (Doug) last name?
does it start with a W?
04-02-2006, 06:41 PM
#93
MySQL Error
i don't doubt it can be done, i just dont think that it will be as simple as bypassing the transformer and hooking up a regulated psu. The thing you were talking about specifically may be different or maybe some really talented people figured out how to power it. I'm just not one of them
it starts with a 'S'
i'll talk to him about a 4 chan unit and what the problems of 'two' 2-chan units would be.
Just a side note, i'm doing all of this for you guys :-) the m-audio soundcard i purchased looks like it's going to work for me :-) but i really want to explore other possibilities too, that's why i'm doing this. Software eq and x-overs are going to be really important with this usb dac solution.
hey red, when you tune, do you give each chan a different eq setting? or do they all have the same eq settings?
New System in progress:
M10k
Phaze TD1500 ~> Seas g18rnx/p
Zapco Ref 500.1 ~ 12" tc-9
Transflective Xenarc
My Car Pc Install
04-03-2006, 04:44 AM
#94
MySQL Error
so i just got a reply from doug and he said that running two of these probably isnt a good idea...so much for my theory.
the other place that i had linked to; stereo-link, had this to say:
Quote:
The line level out of the stereo-link is 2V rms, the standard line level out for home audio systems (eg CD players). The computer sound card standard is 1V rms.
For clarification, the DAC uses 3 power supply voltages: 3.3V for the digital, and +/- % for the analog section. There are on-board regulators for each of these.
We will be introducing a high-end audiopile version within a month that will have a more robust power supply running at +/- 8V, and the headphone output will be capable of a little more than 4 V out, but the cost will also be quite a bit more.
Hope this helps.
I guess that is why we are having such an issue with getting 4v. home audio gear isnt boosting there signal to avoid noise...since it's a clenaer environment.
M10k
My Car Pc Install
04-03-2006, 05:14 AM
#95
MySQL Error
ok, me again...
so doug is freakin awesome. he already replied. here is the email conversation we had and his solution:
from doug:
Quote:
I'm not sure what you mean by a four channel version. If you mean 4 channels of decoding (quadrophonic rather than stereo) I don't think it can be done, but I also don't know of any recordings that are quadrophonic since the early 70's. If you mean having 2 sets of outputs, you can simply parallel the outputs and connect two wires coming out of each channel. You could also use a Y cable of some sort.
As for running 2 at a time, I doubt you can run 2 usb soundcards at once. To do it, you would need to configure something at the computer itself. Also, you would need to have some extra current as this card, because of the opamp, buffers, and dac will not play well with other usb devices. The TDA1543 draws about 50ma, the amp portion will probably draw a little less than that, and the pcm2707 will draw a little. If you consider that usb can supply 500mA at 5V, that this soundcard is converting that 5V to 14 or 18V at about 70% efficiency, this means that you only have about 125 to 150mA to work with. It should be fine for one, but I doubt for 2.
Doug
my reply:
Quote:
well, the common setup in car audio is to have a set of outputs for the front door speakers and output for the sub. (acutally ther are another set for the rear speakers, but we arent concerned about that. Our problem is that we'll need these outputs at 4volts and also to cross them over on the software side of things (that we would have to take care of). if we split them off with a y-cable then we'd be sharing the power to each input, effectively cutting the voltage in half (is my hypothesis correct?). we could always just build an x-over after the amp but before the speakers but we were trying to have the cleanest/streamlined solution as possible.
Quote:
No, the 2 voltages in parallel are equal. However many outputs you put in parallel, they will all have the same voltage across them.
However, you can only draw so much current, and if you go into 2 inputs from one output, the amount of current that can be drawn for each output is cut in half. However, the buf634 can provide a ton more current than you will ever need (about 250mA), and you will reach the limits of the usb long before you begin to stress the buffer.
The software crossover would not be possible, however. My advice would be to use a cap (in parallel) and a resistor (in series) to make a low pass filter on one of the parallel lines out. Way less work and sounds better too.
-d
M10k
My Car Pc Install
04-03-2006, 07:54 AM
#96
_
as for the question about tuning - yes, each SPEAKER has it's own EQ setting....each speaker is also on it's own independent channel as well. (4 channel Audison)
as for the rest - will read it once I get to work - don't have time right now.
04-03-2006, 09:19 AM
#97
_
ok - had a chance to read this...
the idea of takinga single output and splitting it to multiple channels isn't ideal IMO, but I don't REALLY see anything wrong with it....
just would prefer dedicated outputs is all...
after all - stereo is stereo...
5.1 or DTS is a different story though
04-03-2006, 06:14 PM
#98
MySQL Error
well, here is some more brain food. this one was a reply from a company called 'echo audio' whom makes soundcards that are pci or firewire (so that covers you red):
Quote:
Hello Scott,
Sounds like a cool setup. We are planning on adding a "bass management"
feature to our console which would probably be able to do what you're
looking for. But, that is a long ways in the future. We really haven't
had any demand for something like that. Here are a few other
possibilities that come to mind: If you're just playing out of Windows
Media Player, they have some built in EQ and you might be able to find a
plugin to do what you're looking for. I'm not aware of software that
does exactly what you're looking for. But, you might be able to use
standard recording software with "rewire" support to pipe audio into the
software, filter the channels and pipe it out the sound card. You might
also play out of our digital output, loopback into the digital input,
record into your filter software from the digital input and play out the
analog output.
Sorry we aren't aware of a simple way to do what you're looking for.
But, there must be a way to make it work! Layla or Gina3G will both
work for everything described above.
i think we should all look into the whole 'rewire' support now
here is echo's website:
http://www.echoaudio.com
M10k
My Car Pc Install
04-04-2006, 03:24 AM
#99
MySQL Error
this was posted in my thread about adding vst support to centrafuse:
i'm totally with you on the vst plugins. the're are numerous high-quality plugins available.
I use a soundscape mixtreme 192 ( http://www.sydec.be), a soundcard which can process native use of vst plugins. great!! using a 'tube warmifier' plugin right now, absolutely amazing!! downpart are the drivers (at the moment), which doesn't support hibernating...
But sound uality is superb and you can always upgrade the external D/A converter
if i'm reading this right, we can use the vst plug-ins if we get this card...now just to find out what options are available
M10k
My Car Pc Install
04-04-2006, 01:36 PM
#100
MySQL Error
last bit of GREAT info from the echo people (they have been so helpful)
MY EMAIL:
Quote:
> sorry, me again.
> one last question. what is the voltage output on the balanced outputs?
> thanks,
> scott
ECHO'S REPLY
Quote:
Approx 5.75Vrms
Your laptop should be OK for this application.
Thanks for your inquiry.
you guys would need to convert the balanced to unbalanced but 5.75Vrms!!
not bad for those of us that can use pci cards... ~$270
if we can get a good software eq and x-over, we could have a better and less expensive option then the alpine (plus we can control everything from the computer)
M10k
My Car Pc Install
04-04-2006, 01:52 PM
#101
_
very nice!
the VRx amplifiers would work great in this situation...balanced ins!
one thing though, Echo's cards don't have your typical rca inputs or outputs? or am I just missing that?
they just have 1/4", right?
04-04-2006, 02:04 PM
#102
_
One other question.
Did they provide you with any details about the specifics of their components?
Like the brands of their internals or anything?
04-04-2006, 02:06 PM
#103
MySQL Error
nope, i'm not sure what to even ask in regards to that.
M10k
My Car Pc Install
04-04-2006, 02:32 PM
#104
wait wait wait...you want each speaker to have indepenant eq settings??? what would be the purpose of this? whouldn' the slightest change in environment ruin the work put in? I understand i'm noob at this, but what about cancelling frequecies and whatnot? I get having an eq per side(not really, but whatever), but maybe i'm not audiophile enough to do per speaker...
Carputer Progress: Here we go again...
THE GF THEME
Genesis has speed
Genesis has class
Genesis sent money
before your a__;)
Join the fight against carputters. EMAIL ME!
04-04-2006, 02:42 PM
#105
MySQL Error
i think the per speaker setup is for competition and true audiophile purposes only. I wont be going to that extreme (as i'm not great at tuning and i dont have a rta). so for the general public, we will just be concerned with the overall eq settings. hopefully with the vst plug-ins though, red will have the flexibility she needs to set up her system for competition.
M10k
My Car Pc Install
| Thread Tools |
| Display Modes |
Linear Mode
