Old 03-23-2006, 04:31 PM   #16
Raw Wave
tj!2k4's Avatar
tj!2k4 has much to be proud oftj!2k4 has much to be proud oftj!2k4 has much to be proud oftj!2k4 has much to be proud oftj!2k4 has much to be proud oftj!2k4 has much to be proud oftj!2k4 has much to be proud oftj!2k4 has much to be proud oftj!2k4 has much to be proud oftj!2k4 has much to be proud of
Quote: Originally Posted by Scouse Monkey
WTF!
1 - you stole my idea
2-matchstick = gay and will break
oh man, the plagiarism never ceases! lmao
Dr. Ron Paul for President 2008
Hope for America - http://www.ronpaul2008.com
Who is Ron Paul? - Why do we need Ron Paul?
CarPC Newbs Start Here: All your questions answered, as if by E.S.P.
tj!2k4 is offline   Reply With Quote
Old 03-23-2006, 04:33 PM   #17
Raw Wave
edrex's Avatar
edrex has much to be proud ofedrex has much to be proud ofedrex has much to be proud ofedrex has much to be proud ofedrex has much to be proud ofedrex has much to be proud ofedrex has much to be proud ofedrex has much to be proud ofedrex has much to be proud of
one more idea..but could **** it....clean a soldering iron...heat the female part around the broken bit and have the amp on its end. then tap the conenctor. the connector bay expand and lose its grip slightly.
C'mon, would you do that if it was your amp?
Spent so far: $1,755
Check Out My Work Log for Specs/Pics
CarPC Progress[!!!!!!!!!!!!!!].....Installation[---------+].....Pastrami Progress[!!!!!!!!!!!!!!]
Quote:
Don't mess with Texas.
It's not nice to pick on retards!
edrex is offline   Reply With Quote
Old 03-23-2006, 04:40 PM   #18
MySQL Error
Scouse Monkey's Avatar
Scouse Monkey has much to be proud ofScouse Monkey has much to be proud ofScouse Monkey has much to be proud ofScouse Monkey has much to be proud ofScouse Monkey has much to be proud ofScouse Monkey has much to be proud ofScouse Monkey has much to be proud ofScouse Monkey has much to be proud ofScouse Monkey has much to be proud ofScouse Monkey has much to be proud of
yup
If you want more answers on anything I have posted you can find me at digital-car.co.uk
or skiing or diving or doing somthing else fun!
Scouse Monkey is offline   Reply With Quote
Old 03-23-2006, 04:40 PM   #19
Raw Wave
tj!2k4's Avatar
place it in a centrifuge with the connector bay facing out, and spin it up to 5Gs. Then drill a hole into a matchstick, and apply some super glue to the soldering iron and it'll come right out.
Old 03-23-2006, 04:42 PM   #20
Raw Wave
edrex's Avatar
Is that while it is still on the centrafuge?
Old 03-23-2006, 04:42 PM   #21
Raw Wave
tj!2k4's Avatar
yes.
Old 03-23-2006, 04:44 PM   #22
MySQL Error
tie it to your roof, connector 1st and then crash into a cliff at 150mph!
Old 03-23-2006, 04:45 PM   #23
MySQL Error
or give the amp to NASA and ask them to tie it down in the airlock and open the door - maybe the connector will get sucked, sorry blown, out into space
Old 03-23-2006, 05:46 PM   #24
sama's Avatar
sama has much to be proud ofsama has much to be proud ofsama has much to be proud ofsama has much to be proud ofsama has much to be proud ofsama has much to be proud ofsama has much to be proud ofsama has much to be proud ofsama has much to be proud of
WTF!
1 - no I didn't, I said it differently and I dont' see any patents
2 - a matchstick is only gay if you do an act with it
///Mputer - Velocity - TomTom - Vision - Bezel - CarPC
sama is offline   Reply With Quote
Old 03-24-2006, 12:08 AM   #25
gmax111 is on a distinguished road
use a wirefeed welder and spark an ark on the rca female jack then move ur arc across the jack to the hole then tack the end of ur wire to the pin and wait for it to cool... then pull it right out... whaaala... then use some solder to fill the big ******* u gave to ur amp... but first dont forget to use a gay matchstick with superglue on the end to perform an act with ur newly acquired *******... then fill it with the solder buttplug
gmax111 is offline   Reply With Quote
Old 03-24-2006, 12:31 AM   #26
Raw Wave
tj!2k4's Avatar
so edrex, it's been a while.. which method worked?
*please say centrifuge*please say centrifuge*please say centrifuge*
Old 03-24-2006, 12:56 AM   #27
Super Moderator. If my typing sucks it's probably because I'm driving....
turbocad6's Avatar
turbocad6 is a splendid one to beholdturbocad6 is a splendid one to beholdturbocad6 is a splendid one to beholdturbocad6 is a splendid one to beholdturbocad6 is a splendid one to beholdturbocad6 is a splendid one to beholdturbocad6 is a splendid one to beholdturbocad6 is a splendid one to behold
why not just thread the tip of a sheetrock screw into the little hole in the center of the broken pin & just pull it out?
turbocad6 is offline   Reply With Quote
Old 03-24-2006, 01:38 AM   #28
furball69 is on a distinguished road
That's what I was gonna say!
furball69 is offline   Reply With Quote
Old 03-24-2006, 03:27 AM   #29
sama's Avatar
or maybe wax it out?
Old 03-24-2006, 03:36 AM   #30
MySQL Error
scott_fx's Avatar
scott_fx is on a distinguished road
maybe use one of these:
i think they are called 'bullet' connectors
just stick it an and pull it out...just like....nevermind
New System in progress:
M10k
Phaze TD1500 ~> Seas g18rnx/p
Zapco Ref 500.1 ~ 12" tc-9
Transflective Xenarc
My Car Pc Install
scott_fx is offline   Reply With Quote
Creating a stronger input plug for RCA Video on Lilliput 619 Darek85 LCD/Display 2 12-12-2005 06:44 PM
Where to purchase high quality SHORT rca to mini-phono (1/8" plug) cables? sivart321 General Hardware Discussion 0 07-15-2005 08:59 PM
could I connect a laptop headphone jack to a radio with an Aux in rca plug. Amax Car Audio 2 03-01-2005 06:23 PM
usb male to female stub plug dim-8 General Hardware Discussion 5 10-03-2004 06:17 AM
3.5 stereo jack to 2 male RCA out? judoGTI General Hardware Discussion 7 09-07-2004 04:28 PM
