Here's the
best way to remove a broken male rca pin in a female rca plug:
1.) Find a needle (like the one ya mammy used to hem your church pants)
2.) On a hard surface, bend the very tip of the needle slightly so that it forms a tiny barb.
3.) heat the tip of the needle with a lighter until it glows red hot.
4.) stick the needle into the plastic core of the broken RCA pin
5.) wait a few seconds for it to cool
6.) pull the needle out, and the broken tip should follow!
Steps 3 & 4 you have to do really quick or the needle will cool down to early...make sure you got a steady hand or you will have to repeat until you get it in.
You will see that this method works like a charm!!! All the rest is a bunch of nonsense. Why do you need a soldeirng gun or a matchstick and puddy??? You monkeys would fail at the MacGyver School of Survival...
