Old 03-23-2006, 04:10 PM   #1
Raw Wave
edrex's Avatar
edrex has much to be proud ofedrex has much to be proud ofedrex has much to be proud ofedrex has much to be proud ofedrex has much to be proud ofedrex has much to be proud ofedrex has much to be proud ofedrex has much to be proud ofedrex has much to be proud of
Unhappy Help - Broken male RCA tip in female plug!
One of my audio cables broke the tip off in the RCA on my amp. The broken part starts about 1/8" from the surface and I can't find a way to get it out.
Does anyone know of anything that I can try?
Thanks,
ed.
Spent so far: $1,755
Check Out My Work Log for Specs/Pics
CarPC Progress[!!!!!!!!!!!!!!].....Installation[---------+].....Pastrami Progress[!!!!!!!!!!!!!!]
Quote:
Don't mess with Texas.
It's not nice to pick on retards!
edrex is offline   Reply With Quote
Advertisement Sponsored links
Old 03-23-2006, 04:12 PM   #2
MySQL Error
jcdillin's Avatar
jcdillin is on a distinguished road
sharp pointed tweezers? Best way though is probably going to be take the cover off the amp and push it out from the back, will prevent damage to the rca plug from fussing with it.
肚子笑痛了
S60 Install
jcdillin is offline   Reply With Quote
Old 03-23-2006, 04:21 PM   #3
Raw Wave
tj!2k4's Avatar
tj!2k4 has much to be proud oftj!2k4 has much to be proud oftj!2k4 has much to be proud oftj!2k4 has much to be proud oftj!2k4 has much to be proud oftj!2k4 has much to be proud oftj!2k4 has much to be proud oftj!2k4 has much to be proud oftj!2k4 has much to be proud oftj!2k4 has much to be proud of
crazy glue the part that's protruding to something else...?
Dr. Ron Paul for President 2008
Hope for America - http://www.ronpaul2008.com
Who is Ron Paul? - Why do we need Ron Paul?
CarPC Newbs Start Here: All your questions answered, as if by E.S.P.
tj!2k4 is offline   Reply With Quote
Old 03-23-2006, 04:21 PM   #4
Raw Wave
edrex's Avatar
Thanks JC. There is no room for tweezers, and next to no room for getting behind it. I may have to desolder the plug and take it out, but I don't want to mess with it (read: mess it up) that much.
Was hoping someone may know a trick or two for it.
Old 03-23-2006, 04:22 PM   #5
MySQL Error
Scouse Monkey's Avatar
Scouse Monkey has much to be proud ofScouse Monkey has much to be proud ofScouse Monkey has much to be proud ofScouse Monkey has much to be proud ofScouse Monkey has much to be proud ofScouse Monkey has much to be proud ofScouse Monkey has much to be proud ofScouse Monkey has much to be proud ofScouse Monkey has much to be proud ofScouse Monkey has much to be proud of
bit of super glue on the end of a matchstick?
If you want more answers on anything I have posted you can find me at digital-car.co.uk
or skiing or diving or doing somthing else fun!
Scouse Monkey is offline   Reply With Quote
Old 03-23-2006, 04:22 PM   #6
Raw Wave
edrex's Avatar
Hmmm... its a thought, although I would risk getting glue inside the plug and never getting it out.
Old 03-23-2006, 04:23 PM   #7
Raw Wave
tj!2k4's Avatar
c'mon man! come up with something original!! you think just because you said "super glue" makes it different than my suggestion??!!!!
lol
Old 03-23-2006, 04:25 PM   #8
Raw Wave
edrex's Avatar
I'm surprised he didn't jump on the "push it from behind" comment... more his style!
Old 03-23-2006, 04:25 PM   #9
MySQL Error
i was trying to post that before you did. had a fookin login problem!
You could try carefull drilling into the bit with a 1-1.5mm PCB drill then glue summit slim inside - like a paperclip.
Old 03-23-2006, 04:26 PM   #10
MySQL Error
CHUMBA!
Old 03-23-2006, 04:26 PM   #11
sama's Avatar
sama has much to be proud ofsama has much to be proud ofsama has much to be proud ofsama has much to be proud ofsama has much to be proud ofsama has much to be proud ofsama has much to be proud ofsama has much to be proud ofsama has much to be proud of
if u push against it, is it firm? if so, carefullk drill into it with a tiny drill bit, then use half a matchstick with glue. that'll do it
///Mputer - Velocity - TomTom - Vision - Bezel - CarPC
sama is offline   Reply With Quote
Old 03-23-2006, 04:29 PM   #12
Raw Wave
edrex's Avatar
Thanks for all the suggestions!
I think I will try to drill it first, then the glue to pull it out. Will post back if it works or I completely **** up my amp and need to buy a new one (or just never have sound to the front right speaker again!).
Cheers fellas.
Old 03-23-2006, 04:29 PM   #13
Raw Wave
tj!2k4's Avatar
well, you did say matchstick, so I'll give you credit this time..
Old 03-23-2006, 04:29 PM   #14
MySQL Error
WTF!
1 - you stole my idea
2-matchstick = gay and will break
Old 03-23-2006, 04:30 PM   #15
MySQL Error
one more idea..but could **** it....clean a soldering iron...heat the female part around the broken bit and have the amp on its end. then tap the conenctor. the connector bay expand and lose its grip slightly.
Creating a stronger input plug for RCA Video on Lilliput 619 Darek85 LCD/Display 2 12-12-2005 06:44 PM
Where to purchase high quality SHORT rca to mini-phono (1/8" plug) cables? sivart321 General Hardware Discussion 0 07-15-2005 08:59 PM
could I connect a laptop headphone jack to a radio with an Aux in rca plug. Amax Car Audio 2 03-01-2005 06:23 PM
usb male to female stub plug dim-8 General Hardware Discussion 5 10-03-2004 06:17 AM
3.5 stereo jack to 2 male RCA out? judoGTI General Hardware Discussion 7 09-07-2004 04:28 PM
Content Relevant URLs by vBSEO 3.3.0
"VaultWiki" powered by VaultWiki v2.5.2.
Copyright © 2008 - 2009, Cracked Egg Studios.Ad Management by RedTyger
