Old 03-28-2006, 05:25 PM   #1
Tainted Love
Cris's Avatar
Cris is on a distinguished road
HDD&Engine noise, only with the carpc
This is how I have my sound:
Carpc in the back --> quality RCA cable to aux input from the HU upfront --> quaility RCA cables to amp with sub in the back.
I have all power wires through the left side, signal wires on the right side, USB/VGA/AV through the middle. Ofcourse, they all meet up in the back...
All wires used are high quality wires.
I have a good grounding point, down to bare metal (one for both carpc and amp).
I tried to groung the case, no luck. Tried a ground loop isolator, still no luck. Also tried a USB soundcard, still no luck.
The HDD&Engine noise is present through ALL the speakers. It's also present without RCA leads or the VGA cables plugged in.
I'd also like to mention that with the Radio or CD, the noise is NOT present. Also, the noise isn't that high in level, so the sound is good, but it shouldn't be there.
So, Red, and other Car Audio gurus, what else can I do?
Cris is offline   Reply With Quote
Old 03-28-2006, 05:33 PM   #2
Raw Wave
tj!2k4's Avatar
tj!2k4 has much to be proud oftj!2k4 has much to be proud oftj!2k4 has much to be proud oftj!2k4 has much to be proud oftj!2k4 has much to be proud oftj!2k4 has much to be proud oftj!2k4 has much to be proud oftj!2k4 has much to be proud oftj!2k4 has much to be proud oftj!2k4 has much to be proud of
<ot>when did you get another car?</ot>
try grounding pc & amp to the same spot?
Dr. Ron Paul for President 2008
Hope for America - http://www.ronpaul2008.com
Who is Ron Paul? - Why do we need Ron Paul?
CarPC Newbs Start Here: All your questions answered, as if by E.S.P.
tj!2k4 is offline   Reply With Quote
Old 03-28-2006, 06:02 PM   #3
Tainted Love
Cris's Avatar
I got rid of the Megane a long time ago, and got a good deal on an Astra in the meantime. Still saving up for my dream car, the latest 5 series...
The PC has always been in the Escort.
They are both grouded in the same spot. I tried grounding them to different ponts but no luck.
Old 03-29-2006, 07:32 AM   #4
Tainted Love
Cris's Avatar
Old 03-29-2006, 07:41 AM   #5
_
RedGTiVR6 has a spectacular aura aboutRedGTiVR6 has a spectacular aura aboutRedGTiVR6 has a spectacular aura about
some HUs have an aux input level adjustment - if youre HU does, check that
also, try and ground EVERYTHING to the same point, HU/Computer/Amplifiers/etc
there's also the chance that the RCAs from the HU back to the amplifiers are carrying some noise. (another reason optical is preferred IMO)
let us know about these possibilities!
Jan Bennett
RedGTiVR6 is offline   Reply With Quote
Old 03-29-2006, 08:02 AM   #6
Tainted Love
Cris's Avatar
No, it doesn't. It's a Panasonic CQ-7300N.
Everything is connected to the same point...
I'm not sure, because the noise isn't present with the Radio or CD. I'm thinking more likely it's the RCA cable comming from the carpc to the aux input of the HU.
As I said, the noise is still there even without the RCA leads plugged in...
Also, the speaker cables have all been replaced by high quality cables...
Old 03-29-2006, 08:14 AM   #7
sama's Avatar
sama has much to be proud ofsama has much to be proud ofsama has much to be proud ofsama has much to be proud ofsama has much to be proud ofsama has much to be proud ofsama has much to be proud ofsama has much to be proud ofsama has much to be proud of
have you tried standing on your head?
do you mean the noise is still there without the RCA's plugged in to the carputer but still into the HU, or not into the HU at all?
///Mputer - Velocity - TomTom - Vision - Bezel - CarPC
sama is offline   Reply With Quote
Old 03-29-2006, 03:13 PM   #8
Tainted Love
Cris's Avatar
Yes the noise is still there without the RCA's plugged in to the carputer...
I can't get the RCAs out of the HU becuase I can't reach them...
I tried standing on my head, it just made it worse...
Old 03-29-2006, 04:46 PM   #9
sama's Avatar
I recon the long lead is picking up noise from somwehere else. perhaps there's a wire (fuel pump maybe) that's running parallel to the RCA cable somewhere.
you want to try to keep audio lines at least 8" away from power lines.
Old 03-29-2006, 04:48 PM   #10
sama's Avatar
mp3car forums have spazed out
Old 03-30-2006, 10:29 AM   #11
Tainted Love
Cris's Avatar
Could be, as the fule tank is right under the back seat, and as far as I know the ful pump is somwhere close to the tank.
I too think it's the RCA leads picking up noise from somewhere, but unfortunatly there's nothing I can do to relocate them, as the whole car is full of wires...Perhaps I could pull them out to the front and see if the noise is still there...thus getting them out the fuel pump's range or other electrical devices in the back...
Old 03-30-2006, 10:47 AM   #12
sama's Avatar
that's a good idea. if you don't get noise, then keep laying the cable slowly along the path it's currently in, until you get the noise. that will tell you where abouts your noise is coming from. Perhaps then you can sheild that? maybe some lead as it's soft. no idea where u'd get it!
shave a load of pencils
or maybe replace the rca cable wihta custom made one that is made up of 2 twisted pairs. may not offer the same quality as a full on OFC cable, but hey what's better? OFC + whine or non-OFC + no-or-less-whine?
Old 03-30-2006, 10:58 AM   #13
_
what RCAs are you using?
Jan Bennett
Old 03-30-2006, 06:38 PM   #14
Tainted Love
Cris's Avatar
I'll try just that.
The noise is barely hearable to someone that doesn't know it's there, but for me it's really annoying...it shouldn't be there...you know what I mean...
They're the RCAs that came with an amp kit. Not a top brand, but better that a no name one...Phonocar. They look pretty quality.
These are connected to the PC, through an RCA-Jack adapter, like this one.
Old 03-30-2006, 07:56 PM   #15
_
hrmmm - sounds sketchy to me...
Jan Bennett
Alternator Whine Only With Carputer tbird2340 Car Audio 25 06-29-2007 03:36 AM
100% noise free carpc setup? jeffmat Car Audio 19 02-06-2006 06:43 AM
Got rid of BUZZ noise!! bleunetizen General Hardware Discussion 3 10-30-2005 08:20 PM
Troubleshooting: NOISE RedGTiVR6 Car Audio FAQ 0 03-26-2005 11:31 AM
Noise!! AARGH! sq_geek General Hardware Discussion 23 09-21-2004 02:33 PM
