Old 03-29-2006, 12:24 AM   #1
debugger's Avatar
debugger is on a distinguished road
Carputer next to the subs?
Does anyone know if its bad to have a carputer next to box with subs in the trunk?
debugger is offline   Reply With Quote
Old 03-29-2006, 12:37 AM   #2
Mandos's Avatar
Mandos is on a distinguished road
http://www.mp3car.com/vbulletin/car-audio/72685-subs-computers-do-they-mix.html
Was just discussed 2 days ago
Chris Schempp
Elemental Designs
Scion tC in progress
Mandos is offline   Reply With Quote
Old 03-29-2006, 12:42 AM   #3
pradecki is on a distinguished road
i haven't tried it out but im planning on doing just that with my setup that im building ove rthe next month. I think the vibration would severly hurt the life and reliability of a hard drive not to mention all of the solid state components. I was planning on building a wooden box that will encompass my computer case, the case wil be metal but sit on blocks of foam inside the wood box which will be bolted in place. Then I'll cut out holes for placing 4 80 mm fans 2 in 2 out in the wood box, and i will have some standard fans in the case will not be covered by foam (air will be able to flow to the internal components to prevent over heating but the foam should reduce much of the vibration. Since I am welding my case together my self i am planning on having the hard drive in the case held in 3 directions by some runner straps (thick rubber bands). This will help just for overall vehicle movement and some vibration dampening. Since i haven't built this yet i don't knwo how well it will work. I know someone from missourri who did somethign similar but had too much foam so he had overheating problems. I will post on here how it works after i have it built. has anyone else tried something similar?
pradecki is offline   Reply With Quote
Old 03-29-2006, 01:08 AM   #4
debugger's Avatar
How about using "DYNOMAT PREMIUM" or anyother sound dumping solutions on the case?
Old 03-29-2006, 01:25 AM   #5
that could help, but there will be direct air flow into the case for cooling unless i go w/ liquid cooling. Thus I wanted to dampen the airwaves that are going into the case and foam would do a better job of this then dynomat, dynomat would help reduce the vibration of the main case not free moving air
Carputer wont power up once Amp is installed Legrath Newbie 6 03-20-2007 11:16 PM
My Weekend of carputer hell! Sonicxtacy02 General Hardware Discussion 10 01-05-2005 09:19 AM
Carputer integration with HUGE car audio system, help please septicdeath Newbie 19 12-04-2004 06:37 PM
Good time to buy carputer components? Linus General MP3Car Discussion 19 11-25-2004 09:57 PM
semi-newb, need help planning for carputer in a Mazda3 Stealth915 Newbie 9 10-23-2004 03:25 AM
