Max power is a terrible thing to base off of. What we need to know is RMS power.
However, I agree with DJiK, the 60A fuse should be sufficent. just to give you an Idea, add up all the fuses that are on your amps, if it's less than 60, you are more than fine, if it ends up not too much more than 60, eg. 80A, you should still be OK.
Worst thing that happens is you blow the fuse.... not a big deal
