Old 03-29-2006, 01:09 PM   #1
skygtr is on a distinguished road
can this be done w/o carputer?
I've searched but didn't find a definate answer. What i wanted to do as a temporary solution for my need of GPS until i get the carputer running is using a usb GPS reciever for my in-dash dvd unit. Is there a way i can connect the reciever and run the map through the DVD slot? I found a thread saying that only a Garmin GPS reciever can do this, so not sure if it is worth a try. thanks in advance
skygtr is offline   Reply With Quote
Old 03-29-2006, 01:13 PM   #2
Will Albers is on a distinguished road
huh? well we would need to know what your indash DVD player make and model is. We would need to know what software/maps you have. We would need to know the GPS.
Without a whole lot more information, i can definetly say "maybe"
Will Albers is offline   Reply With Quote
Old 03-29-2006, 01:20 PM   #3
_
RedGTiVR6 has a spectacular aura aboutRedGTiVR6 has a spectacular aura aboutRedGTiVR6 has a spectacular aura about
if the in-dash unit has an input that you could use with the GPS unit, possibly?
what will said though, need more info!
Jan Bennett
RedGTiVR6 is offline   Reply With Quote
Old 03-29-2006, 01:21 PM   #4
It is a mayron& davis A7 in-dash dvd unit, which plays all CD formats includes DVD. Software is probably going to be anything that is compliance with NMEA-0183...street finder, etc... As for the receiver it is a generic usb connection. This is a experiment but not sure if i should start because im working on my carputer and just want GPS right now.
Old 03-29-2006, 01:27 PM   #5
_
NOW NOW! I WANT IT ALL NOW!
hehe - reminds me of hte kid in Charlie and the Chocolate factory...lol
Jan Bennett
Old 03-29-2006, 01:35 PM   #6
u need the spec of the gps receiver? hahaha im not trying to hide anything just don't know much about making it work without a computer but these are the spec for the gps reciever:
UG-200 USB 12-Channel GPS Receiver
General Features:
USB interface
12 channel GPS receiver
Standard NMEA-0183 V3.01 GPS protocol
Onboard patch antenna
4000 simultaneous time-frequency search bins
SBAS (WAAS, EGNOS) support
-137dBm acquisition sensitivity
-145dBm tracking sensitivity
<10 second hot start
<45 second cold start
5m CEP accuracy
Low power consumption: 90mA
Magnetic base
6-foot USB cord
Regulatory Approvals:
FCC
CE
Package Includes:
Driver on 3-inch CD
Additional Information:
Requirements:
Available USB port
CD-ROM drive
Software that is able to use a GPS receiver (NMEA-0183 GPS compliant software)
Examples of NMEA-0183 GPS compliant software:
NetStumbler
Rand McNally StreetFinder
Magic e-Map
For my DVD system:
Fully motorized 7" wide screen LCD monitor with 3 position tilt
Manual adjustable viewing angle (left/right)
Mini LCD on front panel for easy tracking and station read out
Full function control buttons with easy read out
Joystick for convenience function maneuver
Big rotary style volume control knob
ISO DIN chassis
DVD/MP3/CD-R/CD-RW compatible
Tone control (tremble & bass)
4 channel preamp line out with separate subwoofer output
1 optical digital input
IR remote control
Auto dimmer
1 video input for rear view camera
2 audio/video inputs
NTSC diversity TV tuner system * 6 disc DVD and 6/10/12 disc CD changer control
Progressive scan
Mutli-source control
6 channel Dolby DTS Ready
Man 250w power output (50w x 4 & 25w x 2)
Old 03-29-2006, 04:08 PM   #7
i guess it will not work since my dvd system does not have a usb connection...is there soemthing i can covert the usb into a regular input jack?
Old 03-29-2006, 04:09 PM   #8
_
I don't believe so....usb carries signal over 4 cables I believe it is. Much like serial. Each pin does something different.
Jan Bennett
Old 03-29-2006, 04:18 PM   #9
Maeveth is on a distinguished road
No, you cannot just hook a GPS reciver into a DVD system. There are several reasons for this.
1. There is not port to connect your GPS to the DVD system.
2. Even if there was a port your DVD system has no GPS mapping software. No you cannot just put software in there because the DVD system will not run it because well its not a computer.
To make a long story short, your DVD system and a PC are two differnt animals completely.
2003 Subaru Impreza TS
Staus: Done.. too lazy to make pictures lol.
Maeveth is offline   Reply With Quote
Old 03-29-2006, 04:19 PM   #10
Raw Wave
tj!2k4's Avatar
tj!2k4 has much to be proud oftj!2k4 has much to be proud oftj!2k4 has much to be proud oftj!2k4 has much to be proud oftj!2k4 has much to be proud oftj!2k4 has much to be proud oftj!2k4 has much to be proud oftj!2k4 has much to be proud oftj!2k4 has much to be proud oftj!2k4 has much to be proud of
define "regular input jack"
Dr. Ron Paul for President 2008
Hope for America - http://www.ronpaul2008.com
Who is Ron Paul? - Why do we need Ron Paul?
CarPC Newbs Start Here: All your questions answered, as if by E.S.P.
tj!2k4 is offline   Reply With Quote
Old 03-29-2006, 04:54 PM   #11
cheap custom title
JC-S60's Avatar
JC-S60 is just really niceJC-S60 is just really niceJC-S60 is just really niceJC-S60 is just really niceJC-S60 is just really nice
Will never work.
Everything nowadays is a computer of some sort, as is your dvd-player... BUT you need compatibility AND an operating system supporting peripherals and software.
The operating system in a DVD-player is VERY basic and simple, won't cut it at all in power, leave alone compatibility with software...
Off course you need a lot of processing power to run complicated software. Even more if running on a "flexible" (meaning compatible with lots of software and hardware, also meaning a lot of abstraction layers) operating system that isn't optimized only for doing GPS (windows/linux can do a lot more, but aren't the most efficient because of their portability).
Much more then you asked for, but a very complete answer, don't you think?
JC-S60 is offline   Reply With Quote
Old 03-29-2006, 05:13 PM   #12
thought so, thanks for the inputs
tested my carputer first time tonight w/o display ccblanket Newbie 3 04-29-2004 05:12 PM
CARPUter w/o cd/dvd drive ericdee Newbie 7 04-28-2004 12:01 PM
CARPUTER SYSTEM w/o MONITOR ericdee Classified Archive 2 04-22-2004 01:28 AM
FS: Carputer system w/o monitor Toups Classified Archive 7 04-21-2004 01:43 PM
FS: Carputer system w/o monitor (Boots in 15 sec) Toups Classified Archive 0 04-01-2004 12:01 PM
