TV Antenna Signal Wire
Looking to put TV antennas in the trunk lid behind the liner...
so I need to route the signal wires to tuner in front.
Should I keep the signal wire(s) away from other electrical harnesses to avoid "distortion" ?
I'm not sure if I should route the wire along either side of the car, where there is big thick harness or thru the middle under the carpet.
thanks
