Yesterday I finally had the time to place my case there where I wanted (in the trunk)
Last 3 weeks I was driving with the PC case on the passangers floor.
Unitl yesterday every was running well. Sound was good without any problem.
But now I have a really strange problem.
I use a 4.1 PCI soundcard. The front speakers are connected to the front-out, and the back speakers to the rear-out put.
If I connect the jack in the rearout-put I hear a very strange noise when the music is off.
When the front jack is connected to thr front-output the sound is not here.
Because I wanted to be shure the the problem came from the cables (maybe running to close to the power cables, I connected the front jack in to the rear out-put. Noise then came back
If I connect the rear jack in to the front out-put noise is gone.
So what I think is that the rear out-put conector is the problem.
Because If it was one of the cables I would have this noise also when I connected the jack in the front-output.
So this is the problem:
frontjack in front out-put , no problem
front jack in rear out-put, NOISE
rear jack in front out-put, no problem
rear jack in rear out-put , NOISE
What could cause this NOISE.
Case Is grounded through the M1-ATX powersupply. This one is connected to the ground of the car.
Like I said, befaore I moved the case the problem wasn't there
