First... I'm installing in a 2006 Nissan Frontier Crew Cab.
What I have:
- a pair of Infinity Kappa 50.7's (5 1/4" components)
- a pair of Infinity Kappa 60.7's (6 1/2" components)
- Infinity Reference 5761a 6-channel amp (already installed)
- JBL GTO1002D Dual-coil 10" sub (already installed)
For reference, here's a link to
a picture of my driver's side door.
Up til now (and probably not the best thing to do) I have the amp connected to the crossovers (under the passenger's seat), which are connected to the factory speaker wires driving the factory speakers. I just haven't had time to install the new door speakers yet.
My original plan was to A.) install the 50.7 woofers in the front doors and tweeters in the factory tweeter dash location (up near the A-pillar), and B.) install the 60.7's (woofers and tweeters) in the rear doors (per Crutchfield's "it fits" recommendations).
Upon further investigation, I read that the woofers & tweeters in a component set should be less than 12" apart, so they act as a single sound source.
But another source I read said that distance isn't really an issue. The important thing is that the woofer and tweeter be equadistant from the listener so that the sound from both speakers arrives to the ear at the same time. I informally measured and this is the case. In my truck, the woofers (low in the doors) and the tweeters (high in the dash) are both about an arm's length away.
However, yet another source recommends mounting both the component woofer and tweeter in the front doors, and leaving the factory dash-tweeter in place.
Now for the options/questions:
1. Are there inherent problems mixing my Infinity Kappas with the presumably cheap OEM tweeters? In other words, if I install the 50.7's (woofers and tweeters) in the doors and leave the factory tweeters in place, am I degrading my overall system?
2. Is the '12" woofer/tweeter distance' rule really a valid rule, or was that other guy right that if they're the same distance from the listener, they'll work just as well?
3. If I opt to replace the factory tweeters (in the dash) with my component tweeters, I have room to install the 60.7 woofers in the front doors (instead of the 50.7's). I would then install the 50.7's (woofers and tweeters) in the rear doors. Is there any benefit to that?
Thanks for the advice.
-meta
