Old 04-06-2006, 01:17 PM   #1
Lathinx's Avatar
Lathinx is on a distinguished road
Preformance HU (200 watt) + 200 watt amp = better?
i have a Grand AM with the monsoon amp installed... after quiet a bit of looking i found that the amp is 200 watts (as good as most new HUs). So anyway... I just replace the rear speakers.. when i bought it the rears where not hooked up.. after pluging them in i found out why... they were dust... ( i thought about takign a picture because of how impressed i was with there condition...
any way.. I got a new pair of http://www.bestbuy.com/site/olspage....=1099388426000
rms 40 watts 4 ohms. peak of 300 ( i like there sound most of all)
So i installed them and they sound GREAT... i've had the car for 6 months... and i don't evne have a woofer and it's Bumping, just from 6x9's
so now I ask.. does the fact that my HU out puts 50 watts all around and the Amp does the same have any affect? or is the Amp just acting as a passthru?
Oh Wtb I'm 21 today :-p (i saw this so i had to add that piece of info)
Just cuase I ask questions, doesn't mean I stop looking for an answer.
Grand AM GT
Plans:
7" touch screen
1.3 ghz laptop (win XP)
replacing the stock sound.
red ground effects
wireless keyboard, mouse and remote.
GPS,Bluetooth,Wi-FI,FM tuner.
Lathinx is offline   Reply With Quote
Old 04-06-2006, 01:23 PM   #2
Neither darque nor pervert
DarquePervert's Avatar
DarquePervert is a glorious beacon of lightDarquePervert is a glorious beacon of lightDarquePervert is a glorious beacon of lightDarquePervert is a glorious beacon of lightDarquePervert is a glorious beacon of light
If you're using the pre-outs from the headunit into the amp (which you should be), then the only amplification is from the amplifier itself, not the headunit.
The amplification from the headunit is only for speaker-level outputs.
And if you're twenty-one now, that means you're an adult. As an adult, you should realize the annoyance factor of all the damn smileys.
LOOKING FOR THE FAQ? IT'S HERE.
You never found that link, did you? Why? It's hard to find in the NavBar across the top of the forums, amongst a lot of other crap.
TELL MP3CAR YOU WANT A LINK TO THE FAQ IN A MORE OBVIOUS, NOTICABLE LOCATION HERE.
Old 04-06-2006, 01:29 PM   #3
Vinister is on a distinguished road
some factory amps are high-level input, but the power definately doesn't "add-up". the only power you have is from the factory amp, which is probably plenty.
Vinister is offline   Reply With Quote
Old 04-06-2006, 02:34 PM   #4
Lathinx's Avatar
First, No i'm not using a Pre-amp out.
reason: i have preamp out for Subs, not for anything else. the other wires where already ran stock for the amp. (this is the Stock Monsoon system)
Second, Yes i do understand Smiles ( ) are annoying, but let me have my fun... i'm a billing clerk.. it's all I got man.
What my main concern is, is that i'm not hurting anything with my set-up since i can't get specs on the Amp (if i had the 500 watt "8-channel" i could), i am thinking of upgrading it, but thats at least 10,000 miles and $500 down the road.
so recap, 50 watts coming from the HU to a 200 watt stock monsoon amp.
Grand AM GT
Plans:
7" touch screen
red ground effects
Old 04-07-2006, 03:43 AM   #5
Ub312g0d's Avatar
Ub312g0d is on a distinguished road
from what it sounds like, the factory amp has high level inputs so you're speakers are only getting the 200 watts from the amp. And I would put a wager that this is peak watts not rms. If youre up to getting another amp you might want to replace your fronts as well.
Ub312g0d is offline   Reply With Quote
Old 04-07-2006, 09:50 AM   #6
Will Albers is on a distinguished road
Is this an aftermarket or factory radio? The factory radio may or may not have amplified out. I really dont know on the monsoon. I can tell you that the monsoon amp is not expecting 50 watts per channel on its high level inputs.
You can run an aftermarket stereo with the factory monsoon amp, but be REALLY careful with volume control. You are going to be able to turn the HU up to probably 5 or 10 before you overdrive the inputs. Sad thing is this is a very low signal to the subs (pre amp oututs). Basically you will not have equal volume to stock amplifier and sub amp.
Here are your options...
(aftermarket) get a hi/lo level convertor and power the factory amp with it... or just use the damn pre-amp outputs and Y em off to all amplifiers like normal people do.
(Factory) Leave it as is... your stereo output is dependent on the amplifier (last amplifier in the chain) which is 200 watts. You could send 1000 watts into the input of the monsoon amp (if it could handle it... but cannot) and you will still only have a 200 watt output.
Will Albers is offline   Reply With Quote
Old 04-07-2006, 01:15 PM   #7
canadapettit is on a distinguished road
Lets get one thing straight, your headunit (aftermarket or factory) does not put out 50 watts. When they say 50x4, 52x4 or 60x4, that is max wattage out of the radio. Aftermarket radios typically put out about 22 watts rms with factory being lower.
Trying is the first step toward failure
canadapettit is offline   Reply With Quote
F.S. 1000 Watt Amp Brand New! customalti05 Classified Archive 3 02-03-2005 12:52 AM
FS: JBL 600.1 600 watt amp xcdhridr Classified Archive 0 08-13-2004 01:10 PM
Queston conerning stinger 200 amp relay vash General Hardware Discussion 2 05-25-2004 11:15 AM
FS: PIII SBC and 200 watt AT PSU Scrapez Classified Archive 5 03-26-2002 03:30 AM
