Ok....
I installed a wired fm modulator into my car today....
I ran the box directly into the back of my car's antenna and because the unit required a 12v power source and ground source, i decided to dismantle my un-used cigarette lighter adapter and use the ground and 12v power source attached to that for my FM modulator. (this ended up working out extremely well, because there was a cigarette lighter adapter sized on/off switch that came with the modulator that fixs perfectly)
(The only evidence of my install...i have to admit, it looks pretty good, haha) -
http://www.flickr.com/photos/28787159@N00/125908717/
So anyway, i hooked everything up....tried it out...and it worked great!
I dismantled all the pieces and started reassembling them so that wires werent exposed at all. After all is said and done, the install looks great....so i go to try it out again....nothing....
Its the same exact setup as i had 5 mins previous, but it doesnt work....
I checked my cars "audio" fuse in the fuse box....it looks fine
I checked my fm modulators fuse and internal components...they look fine
I checked my car stereo's internal components...they all look fine
I even disambled the button and it looked fine.
My only thought left was that maybe I blew the fuse for the cigarette lighter....but...my other cigarette lighter adapter works fine. Unless they are on seperate ciruits, I dont know what the problem could be....
I'm looking for some suggestions of what to try next....
The only thing i can think of doing is going and buying a volt meter and testing the wires that are supposidely "powering" my fm modular...
Thanks guys.
