04-12-2006, 01:44 PM
#1
IS my capacitor bad?
OK so I I am trying to install my new system... I connect all the powers, grounds and remotes to where they needed to be. OF course doing all this while the power wire to the system is disconnected from the battery. So after everything is connected i go to turn on the car and all of a sudden i am getting a buzz from the capacitor, i shut the car off. ANd stupid me I forgot to put the power wire coming from the trunk back on the battery. SO i connected the pwer wire back and i get no buzz but my cap doesnt turn on. I use my multimeter and I get correct voltage everywhere but the cap isnt turning on and it will obviously not turn my amps on. Does the cap just need to be recharged or is it a bad cap now?
2002 Mitsubishi Galant
Carputer Specs:
Via M10K
512mb Ram
60GB HDD
Souund Blaster Audigy2 NX
OPUS ITX PC Case
04-12-2006, 02:04 PM
#2
May be the cap need to be recharged, you must first charge your cap using a 1K ohm resistor and a multimeter to watch the charging process until read 12 V. also be careful do not hold the resistor with you hand you could be burned, the current flowing through the resistor will cause the resistor to heat up.
Hope this help.
04-12-2006, 02:42 PM
#3
My cap, the voltage IS reading 12.4 on the remote and power....Would the cap just lose charge?
Carputer Specs:
Via M10K
512mb Ram
60GB HDD
OPUS ITX PC Case
04-12-2006, 02:51 PM
#4
I called up tech support, they said i need to recharge it with a 27ohm resistor...I checked radio shacks website and they dont carry it, where can i get a 27ohm resistor?
Carputer Specs:
Via M10K
512mb Ram
60GB HDD
OPUS ITX PC Case
04-12-2006, 02:56 PM
#5
May be the problem comes from the remote, try to connect the cap directly to the battery positive use the same positive wire to both remote and main power cap positive, and look what will happen.
04-12-2006, 03:06 PM
#6
the exact value of the resistor is not critical but i recommend you to keep in the 500-1k ohm, your cap should come with a resistor for charging.
Use this one http://www.action-electronics.com/resist1w.htm
04-12-2006, 06:00 PM
#7
Thanks, that worked i appreciate it!
Carputer Specs:
Via M10K
512mb Ram
60GB HDD
OPUS ITX PC Case
04-13-2006, 07:20 AM
#8
You're welcome.
| Thread Tools |
| Display Modes |
Linear Mode
