Old 04-12-2006, 04:15 PM   #1
ComputerDoctors's Avatar
ComputerDoctors is on a distinguished road
Question First carputer...
Hello everyone...got a quick question. I'm designing my first carputer and I'm looking at the various parts. I want to put in one of the Intel-based mb (the MB896F) but I dont see anywhere if it supports 5.1 audio on-board. I know the VIA boards have that capability, but I dont see it for the intel.
Is anybody using that (or another) intel board and know that is supports 5.1?
Any links to documentation on that board would be very helpful.
Thanks,
Amit
ComputerDoctors is offline   Reply With Quote
Advertisement Sponsored links
Old 04-12-2006, 04:57 PM   #2
3onDubs's Avatar
3onDubs is on a distinguished road
You don't want to use onboard audio.
PostCount++
- SrCsTc's Bezel
- Alpine W200/H701
- ED Nine.2X
- OZ Matrix Elites
- ED Nine.1
- Idmax 12's
3onDubs is offline   Reply With Quote
Old 04-12-2006, 05:00 PM   #3
Then what would you recommend? I'm not all that interested in surround sound in my car...but I do want to keep fader control. There will be no HU in the setup. Also, I want decent sound quality....but not looking to win competitions.
oh yea...trying to keep the pc small....the board only has 1 pci slot.
-Amit
Old 04-12-2006, 05:04 PM   #4
0verfiend's Avatar
0verfiend is on a distinguished road
I see a lot of people here running a usb hub, and connecting most of the things inside home PCs via a usb... so a usb sound card.
0verfiend is offline   Reply With Quote
Old 04-12-2006, 05:15 PM   #5
3onDubs's Avatar
I don't have that much experience with car audio, but i can tell you what i've done and learned based on my install.
First, i went with an external sound card and 3.5mm to rca cables going to my amps. My sound sucked @ss....i couldn't hear my subs, got tons of speaker whine...overall wasn't loud or clear.
I then replaced my speakers and amps. Slightly better because of the quality improvment, but the source (soundcard) was hurting. It wasn't all that bad, but i just kept comparing it to when i had my head unit in....and it was nowhere close. I just couldn't be satisfied with the speaker pops and alternator whine and i tried everything to get rid of them...pop stoppers, noise isolators, changed grounding points, shared grounding points...nothing worked.
I then got a digital sound processor...the H701...and all of my problems went away....THE END
lol....the alpine won't win you audio competitions necessarily, but it will put you on the same level as a head unit, so that you have the same potential and sound quality.
PostCount++
- SrCsTc's Bezel
- Alpine W200/H701
- ED Nine.2X
- OZ Matrix Elites
- ED Nine.1
- Idmax 12's
Old 04-12-2006, 05:17 PM   #6
Yea, I considered that option, but what I'm trying to do is keep everything in the double din casing . So the USB option doesn't really work.
What I really need to know is: does the M896F supports the multichannel (5.1) sound?
Also, do I need 5.1 for a car or is there something like 2.1 (I absolutely need a subwoofer out)?
Old 04-12-2006, 05:18 PM   #7
3onDubs's Avatar
4.1
PostCount++
- SrCsTc's Bezel
- Alpine W200/H701
- ED Nine.2X
- OZ Matrix Elites
- ED Nine.1
- Idmax 12's
Old 04-12-2006, 05:19 PM   #8
Pls send me a link to the H701...lemme look into that.
Old 04-12-2006, 05:22 PM   #9
3onDubs's Avatar
You will need this: http://cgi.ebay.com/BRAND-NEW-2006-A...QQcmdZViewItem
And this: http://cgi.ebay.com/ALPINE-RUX-C701-...QQcmdZViewItem
PostCount++
- SrCsTc's Bezel
- Alpine W200/H701
- ED Nine.2X
- OZ Matrix Elites
- ED Nine.1
- Idmax 12's
Old 04-12-2006, 05:27 PM   #10
3onDubs's Avatar
But this alpine would have to sit somewhere else as it won't fit in the double din casing. It also requires the controller (which is only like an inch tall) to be mounted so that u can higher and lower the volume. I find this a plus (having a volume nob), while others see it as a minus (no place to put it).
If you went with the alpine, your going to need a mb that has spidf out. I'm pretty sure that all of the via epia's have this...make sure urs does too.
PostCount++
- SrCsTc's Bezel
- Alpine W200/H701
- ED Nine.2X
- OZ Matrix Elites
- ED Nine.1
- Idmax 12's
Old 04-12-2006, 05:30 PM   #11
That's def. not an option...to much $$$ and no place in the dash for that controller.
So the M896 has 4.1 audio? I see that the VIA has 5.1....is that any good?
What I getting at is...if the MB supports the audio, I can use that and if it sounds like @ss, I'll replace it.
Old 04-12-2006, 05:40 PM   #12
3onDubs's Avatar
I always thought about mounting the controller in my seat so that it's facing the pedals and i can reach down and just higher/lower the volume. Another option was on the side of the center console facing me, so that i can only see it and it's out of the way. A third option was on the left side of the steering wheel below the headlight controls.....but none of these solve the $$ issue.
The via's are great boards and they offer a lot for such a small size. The 5.1 is ok, not great. Many people are using it, but i havn't tried it personally. If worse comes to worse, you can always wire an external usb hub away from your dash and into your trunk or glove box and install an external sound card. Internal sound cards are supposed to be inferior when going analog because they can introduce all kinds of noise to your speakers (hard drive spinning, etc.).
PostCount++
- SrCsTc's Bezel
- Alpine W200/H701
- ED Nine.2X
- OZ Matrix Elites
- ED Nine.1
- Idmax 12's
Old 04-12-2006, 05:48 PM   #13
ok...so what I'm (probably) going to do is get the 896...I'll let you know how the sound is...if it sucks, I'll put in a sound card and try to shield it.
Anyone got a link to a manual for the 896? I would like to get more detailed specs on it...and I dont see them anywhere else.
Old 04-12-2006, 05:55 PM   #14
3onDubs's Avatar
http://www.ibt.ca/MB896.htm
PostCount++
- SrCsTc's Bezel
- Alpine W200/H701
- ED Nine.2X
- OZ Matrix Elites
- ED Nine.1
- Idmax 12's
Old 04-12-2006, 05:58 PM   #15
3onDubs's Avatar
Found a better link: http://www.mp3car.com/store/product_...roducts_id=163
PostCount++
- SrCsTc's Bezel
- Alpine W200/H701
- ED Nine.2X
- OZ Matrix Elites
- ED Nine.1
- Idmax 12's
99 Acura TL carputer project pics Darkshear Show off your project 15 08-23-2007 01:14 AM
Carputer wont power up once Amp is installed Legrath Newbie 6 03-20-2007 11:16 PM
My 2006 Scion xB (portable) Carputer setup! w/pics! breaker021 Show off your project 26 01-05-2007 10:34 AM
sound quality between carputer going through the HU and carputer going to amp lookinco Car Audio 9 08-07-2005 12:27 PM
carputer install: I dare you... Cat Monkey General MP3Car Discussion 42 01-27-2005 06:34 PM
