The MP3car.com Store
Thread Tools Display Modes
Old 05-09-2006, 11:15 PM   #1
My Photos: (0)
need help with amp and sub
I need help choosing amp and sub for my truck I don’t know nothing about car audio
I am looking for some sharp clean bass and same time I want listen to words then just bass I don’t know should I go for 10’s or 12’s what brand what kind of amp what size
I already have installed eclipse cd300 and I have Infinity Reference series in front and back
I want to spend $450 to $500 on good setup including box amp and sub
I have 06 dodge ram ext cab
Any suggestion
brijpat is offline   Reply With Quote
Sponsored Links
Old 05-09-2006, 11:34 PM   #2
Sidewalksalvage's CarPC Specs
Sidewalksalvage's Avatar
Vehicle: 87 Toyota Camry
My Photos: (0)
First use the search function. You can find some good stuff....people dont like to spoon feed. Second try crutchfieldadvisor.com They tell you alot about what you need to know for a car stereo job. and thirdly, i suggest borrowing or buying "The Car Stereo Cookbook" by Mark Rumreich.
My few opinions.
1 if your not looking to kill yourself with bass, one 10" will be plenty (if coupled with a good box)
and 2
Maybe an all in one item would be a cost effective solution (ie amp,box,sub all in one)
good luck
Worklog -- 1987 Toyota Camry Resurrection
Current Progress:
[XXXXXXXXXXXXXXXX====]80% Works Great; Front speakers need to be replaced; On hold while at school.
Brown 2010
Sidewalksalvage is offline   Reply With Quote
Old 05-10-2006, 12:16 AM   #3
MySQL Error
scott_fx's CarPC Specs
scott_fx's Avatar
Vehicle: '99 Chevy Corvette -- '01 Volvo S60 t5 --'03 Honda CBR 600RR -- '97 Suzuki GSX-R750
My Photos: (0)
check out elemental designs, they'll have package deals and it'll get you around 500 bucks.
another great sub to look into is the image dynamics subs. by far it's been the best sub that i have owned.
New System in progress:
M10k
Phaze TD1500 ~> Seas g18rnx/p
Zapco Ref 500.1 ~ 12" tc-9
Transflective Xenarc
My Car Pc Install
scott_fx is offline   Reply With Quote
Old 05-10-2006, 12:23 AM   #4
joego's Avatar
My Photos: (0)
If it were my money going in to a Dodge...
I would go with a 10" Type R sub and MRD-M605 amp combo, and spend the remaining on the box and shipping (from www.onlinecarstereo.com)
With a little more I would get a 10" image dynamics IDQ, and a PPI DCX 300.2 amp.
If I recall your truck has very little room for subs and stuff, so you may want to check out JL audio. JL has "stealth" boxes wich fit Dodge trucks, then it's just a matter of powering it.
One more thing you should also include in your budget wires, if you keep a stock system chances are you'll need line converter (I think thats what they're called) to take the signal from the truck's speakers and into the amp, and unless you're installing this your self then you should also include labour. Keeping all that in mind you may find your choices that fit your budget limit themselves.
Good Luck, and don't buy crap...
joego is offline   Reply With Quote
Old 05-10-2006, 12:24 AM   #5
joego's Avatar
My Photos: (0)
Damn you Scott; you beat me too it!
Old 05-10-2006, 12:47 AM   #6
MySQL Error
scott_fx's Avatar
My Photos: (0)
heh... 'newb'
i have heard good things about those type-r's also. they are really efficient
M10k
My Car Pc Install
Old 05-10-2006, 07:49 PM   #7
My Photos: (0)
Wires can cost a lot, also protection (fuses and fuse holders) are also something that should be kept in mind. They arent that expensive each...but can add up.
Current Progress:
Brown 2010
Old 05-10-2006, 08:32 PM   #8
MySQL Error
scott_fx's Avatar
My Photos: (0)
www.knukonceptz.com has good prices. i'm using thier power cables right now and am pleased
M10k
My Car Pc Install
Old 10-23-2006, 09:43 PM   #9
JpLelko's CarPC Specs
JpLelko's Avatar
Vehicle: 2006/Dodge/Ram
My Photos: (0)
I also have a 2006 Dodge ram quad cab. i found this web site for sub boxes, TopEdgeOnline.com. the boxes are made to fit prefectly underneath the rear seats. they range from about $80 to $120. and as far as subs and amps go, I will always recommend JL audio, althought it might be a bit out of your price range.
Progress:
Planning [XXXXXXXXX-] - 90%
Building [XX--------] - 20%
JpLelko is offline   Reply With Quote
Sponsored Links
Trackbacks are Off
Will stock alternator provide adequate ampage? (CPU + Sub) Cadillac_LoungN Power Supplies 0 07-07-2003 01:52 AM
Sub box rattling!!! ddt General MP3Car Discussion 17 04-07-2003 10:28 AM
Me=Newbie: Do I need an amp? Strix General Hardware Discussion 6 06-28-2002 08:11 AM
Sponsored Links
Ad Management by RedTyger
