Old 05-18-2006, 04:20 PM   #1
1Munkey is on a distinguished road
S/B Live Problem
I've finally gotten my project into my car and have a problem with my S/B live card that I'm not sure how to fix. Every problem I've encountered I've been able to fix due to and so I find myself spending hours learning here but unfortunately I can't find anyone with this problem....
I have my amps hooked to the "turnon" on my m2-atx and it works fine, but my S/B live does not turn on until after windows boots. Thus, I'm hearing a crazy amount of ground loop noise (I have an isolator running from the S/B live to the amps so it's gone once the card is on) and I get a nasty pop when the card kicks on. I guess the solution would be to rig the card to turn on with the amps. Is there a way to set the software to turn on at startup or a way to wire the S/B Live to kickon with the m2-atx "turnon"? How do people with external cards get around this?
It's amazing that no matter how cool it is once it's on, no one will forget that first 15 seconds of crap.
Thanks a bunch.
1Munkey is offline   Reply With Quote
Old 05-18-2006, 04:29 PM   #2
Oh I guess it's also customary to list what I have in it:
ASUS P4B
Pentium 1.4GHz
528 SDRAM
Maxtor 40GB
USB 2.0 Hub
Lilliput 7" w/touch
M2-ATX
DVD - slotload (not in yet, trying to figure out best way to hook it up)
Bluetooth Adapter - have it but need to see how ****ed off I'll get trying to get my Treo to work - since after numerous threads i've come to the conclusions it's probably not going to work
Old 05-18-2006, 04:45 PM   #3
MySQL Error
scott_fx's Avatar
scott_fx is on a distinguished road
how about a delay on the amp turn on lead?
New System in progress:
M10k
Phaze TD1500 ~> Seas g18rnx/p
Zapco Ref 500.1 ~ 12" tc-9
Transflective Xenarc
My Car Pc Install
scott_fx is offline   Reply With Quote
Old 05-18-2006, 05:04 PM   #4
How would you go about creating a 15sec ish delay?
Old 05-18-2006, 09:31 PM   #5
pancit175 is on a distinguished road
I wouldnt use a pulse timer in that situation, due to the fact that it's a temporary activation. I could explain how a DEI 528t pulse timer could be usefull in this situation, but i'd probably over complicate it.
There is a part PAC tr-7, that might be good because its totally programmable:
" Low voltage trigger. Gives you +12v output from headunits that do not have a remote output."
PROGRESS:
pancit175 is offline   Reply With Quote
Old 05-19-2006, 12:32 PM   #6
Thanks. I think my best bet may just be putting a kill switch on the turn on. That way I can kill it for the first few seconds and if I forget to turn it off they would kick off when I kill the engine. Also handy if I forget that I came home blasting the music and get halfway down the block at 7 in the morning when Snoop Dogg "Snoops upside my head" at 120dB. Thanks for the input.
Old 05-19-2006, 02:40 PM   #7
MySQL Error
scott_fx's Avatar
get the delay, you dont want to have to flip a switch everytime you get in the car...ANNOYING!!! i think you may be able to make a simple one with a cap and a resistor.
M10k
My Car Pc Install
Old 05-19-2006, 05:04 PM   #8
albysure's Avatar
albysure
go to http://www.davidnavone.com and get his adjustable 12v timer. thats what i use to avoid the turn on thump from the computer
heres the item:
http://www.davidnavone.com/detail.asp?PRODUCT_ID=N-66A
98% complete. Couple of tweaks to the fabrication.
http://www.cardomain.com/ride/212327/14
albysure is offline   Reply With Quote
Not your typical flicker problem JPuma LCD/Display 17 05-30-2007 10:28 AM
had an all day (9 hr) problem at work.... wizardPC Off Topic 13 10-20-2005 12:50 PM
audio problem tiburonputer General Hardware Discussion 0 08-11-2005 04:58 PM
YAOP (yet another Opus problem) Frankino Power Supplies 14 06-19-2005 12:17 PM
power on problem ??? help please anyone Pingo1969 Power Supplies 26 04-07-2004 08:47 AM
