Old 05-22-2006, 11:48 PM   #1
ridetolive is on a distinguished road
Ground Loop Isolator
There is interference playing out of my subwoofers. Everything from revving the engine to ejecting a CD.
My Set-Up: 3 kenwood 10" subs bridged to a 1200 watt sony amp, connect through a capacitor that is grounded to the car.
When put the ground loop isolator between the RCA cables and the amp, the subs are muted and no sound comes out at all. The same happens when i connect it through the back of my head unit.
Whats going on here?
ridetolive is offline   Reply With Quote
Old 05-23-2006, 10:28 AM   #2
_
RedGTiVR6 has a spectacular aura aboutRedGTiVR6 has a spectacular aura aboutRedGTiVR6 has a spectacular aura about
does the isolator have a small ground wire coming off of it?
try grounding or not grounding it.
Jan Bennett
RedGTiVR6 is offline   Reply With Quote
Old 05-23-2006, 11:20 AM   #3
Will Albers is on a distinguished road
Either the amp or headunit is not ground properly. My guess is that the headunits preamp output's ground is fried.
Plug your ipod into the amplifier inputs, get sound?
Will Albers is offline   Reply With Quote
Re-Ground HU or Ground Loop Isolator? Incinorator Car Audio 5 04-20-2006 08:52 PM
FS: Ground Loop Isolator djXternal Classified Archive 0 03-08-2006 09:47 AM
Best Ground Loop Isolator Telos Car Audio 0 07-22-2005 11:36 AM
I tried everything, can't get rid of this ground loop intense General Hardware Discussion 3 07-10-2005 09:58 AM
ground loop isolator help digital chaos General Hardware Discussion 10 03-11-2001 02:38 AM
