Old 05-24-2006, 01:23 PM   #1
mccdeuce's Avatar
mccdeuce is on a distinguished road
non-monsoon VW guidance
I want to keep my Stock HU but add an amp or at least a sub to my setup. Any recomendations for subs or amps to use in this setup as well as the wiring to tap into would be appreciated.
mccdeuce is offline   Reply With Quote
Old 05-25-2006, 01:02 PM   #2
paulm287 is on a distinguished road
My suggestion, get something along the lines of an Audiocontrol EQX...you can then use the high level inputs (speaker wires from the back of the factory head unit). From here you use RCA cables to the amp(s).
A good cheap solution for amps is Hifonics. I wouldnt recommend buying anything more expensive because the sound is limited by the stock head unit (which leaves much to be desired). For subs, look into Image Dynamics. You can get an ID12 for $111 on Sounddomain.com. These subs are AMAZING for the price and they do well ported, sealed, and IB. They dont require a large enclosure either so you can keep most of your trunk space.
Any other questions just PM me
paulm287 is offline   Reply With Quote
FAQ: Connecting your soundcard to a Volkswagen Monsoon Amp kbyrd The FAQ Emporium 88 09-04-2009 12:32 AM
Camaro / firebird Monsoon setup (NOT VW) HELP camarossguy2 Car Audio 30 04-14-2009 12:02 PM
Need help building VW Monsoon amp input kbyrd Car Audio 95 02-23-2009 03:13 PM
Monsoon system in VW Jetta. HELP!! SteveT178 Car Audio 12 01-14-2006 12:54 PM
Need help with VW MKIV Non Monsoon MVBEAST Car Audio 4 11-18-2005 05:49 PM
