Old 05-24-2006, 03:06 PM   #1
Genesisfactor is on a distinguished road
Automatic Eq change?
Anyone know a player/software/pluging that not only saves a customed EQ setting for a some, but also changes the EQ to a predetermined on as it changes genre? I mean, its kinda sucky to have the heavy bass of Swtich Remix of WIll SMith and Elephant Man followed by an acapella version of Beauitufl Dya by U2...kinda needs a new EQ setting. Hate to have to do that for every song. NAy ideas?
Carputer Progress: Here we go again...
THE GF THEME
Genesis has speed
Genesis has class
Genesis sent money
before your a__;)
Join the fight against carputters. EMAIL ME!
Genesisfactor is offline   Reply With Quote
Old 05-24-2006, 04:13 PM   #2
nate@s-curves is on a distinguished road
Tune your system to perform well on all of them, I never touch my EQ, its a set and forget thing.
My Blog
nate@s-curves is offline   Reply With Quote
Old 05-24-2006, 05:19 PM   #3
no no, not the car's EQ, the computer's EQ. Car EQ is to be set to flatten the car, the computer EQ is what i need adjusted per song. Sometimes i just want more bass in some songs than others. Sometimes i want the highs accented.
THE GF THEME
Genesis has speed
Genesis has class
Genesis sent money
before your a__;)
Old 05-24-2006, 11:16 PM   #4
fonseca's Avatar
fonseca is on a distinguished road
You can easily do that in Road Runner, I believe auto load EQ presets is listed in skincommands.txt. I did it myself for quite some time, although now I'm using a VST EQ plugin. I know exactly what you mean about needing to adjust bass between certain albums. Right now I'm back to using the bass and treble controls on my DSP, which are too broad in their effect. But it's worth the inconvenience for kernel streaming.
In progress: M10000; Travla c134; Xenarc 700TSV; Hitachi 80GB 2.5"; 256MB ULP; M2-ATX; ITPS; Powermate; iKEY SL-88 KB; Holux GM-210; Audiobahn ADD51T w/ COAX/optical converter; Road Runner; iGuidance 2.1
fonseca is offline   Reply With Quote
Old 05-25-2006, 08:15 AM   #5
i mean like, you have rip hip hop genra, its gets a specific eq setting. THen orchestral/vocal, it gets an eq setting then, then rock, then techno...
And then if there are song specifi eq's, they have a preset setting. Basically, by defaut, all songs have a base EQ setting based on genre and then if i want to tweak the songs a bit more, they get the tweaked settings.
THE GF THEME
Genesis has speed
Genesis has class
Genesis sent money
before your a__;)
Old 05-25-2006, 06:31 PM   #6
fonseca's Avatar
You can have a custom preset for every single song if you want, that will load when the song loads, and songs you don't have custom presets for will use whatever standard preset you have your EQ on by default.
http://www.mp3car.com/vbulletin/show...ght=EQ+presets
Old 05-25-2006, 07:20 PM   #7
Thanks. Looked into it. I kinda wish it worked as a seperate peice fo software. Although, since it may be a winamp plugin....
THE GF THEME
Genesis has speed
Genesis has class
Genesis sent money
before your a__;)
What would you do if your girlfriend..... EsKALad Off Topic 123 01-25-2006 01:50 AM
Eq? Ascension FrodoPlayer 10 10-20-2005 08:12 PM
Winamp EQ auto load presets F350 Road Runner 2 08-15-2005 10:22 PM
[Q] Adding EQ, no problem????? helloman General Hardware Discussion 5 04-06-2005 07:10 PM
ebay change of password cruzc_99 Off Topic 1 01-22-2002 04:43 PM
