Old 05-28-2006, 03:43 PM   #1
nato89 is on a distinguished road
Question audio system
hey, im looking for a new sub n amp to go in my 306, £200 is the limit. any suggestions would be great. cheers.
nato89 is offline   Reply With Quote
Advertisement Sponsored links
Old 05-28-2006, 05:26 PM   #2
blazinaspire's Avatar
blazinaspire is on a distinguished road
ok according to tdays exchange rate 200 euro is 254.773 USD
and for that 254.773 you could get a ma audio amp (M700XE ) and one ma audio 12inch sub ( MA12D4 12" )
you can get 250wrms from each chanel from that amp at 4ohm and just hook up each chanel to each voice coil on the sub ( DVC sub ) and then you will have 500 wrms going to that one sub, and trust me ma audio subs will handle more then they are ratted for, it comes out to 280 or so $ us but save up the 26$ its well worth it, i have 550wrms in my car with one 12 inch sub and my wipers move to the bass slightly, and my box is not even to spec
here are the links for the two items
amp
http://www.sonicelectronix.com/item_6561.html
sub
http://www.sonicelectronix.com/item_4085.html
blazinaspire is offline   Reply With Quote
Old 05-28-2006, 10:12 PM   #3
kingeorge36's Avatar
kingeorge36 is on a distinguished road
Don't forget about the aternator and battery and power wires!
I reccomend that before buying high power amps and subs. WIthout any of those improvements your a step behind, plus if you want a higher amp or amps for your other speakers in the future you'll have a good alternator and battery that can handle it!
SUVPUTER:
AMD~SILVERSTONE~AUDIO CONTROL~BOHLENDER GRAEBENER~IMAGE DYNAMICS~ROCKFORD FOSGATE~OPTIMA~STINGER
kingeorge36 is offline   Reply With Quote
Old 05-29-2006, 03:13 AM   #4
MySQL Error
scott_fx's Avatar
scott_fx is on a distinguished road
amp
sub
each voice coil should have the same exact signal. i dont think that wireing each voice coil to it's own chan is recommended. if something happens you could end up ruining the sub
New System in progress:
M10k
Phaze TD1500 ~> Seas g18rnx/p
Zapco Ref 500.1 ~ 12" tc-9
Transflective Xenarc
My Car Pc Install
scott_fx is offline   Reply With Quote
Old 05-31-2006, 06:19 AM   #5
Exclamation audio system
cheers for your ideas, the currency is pounds not euros over here, an i checked out the web address and its like 100euros for shipping!!
my original ideas where for either 1 of these 2 packs from the website below, i found it to be quite cheap compared to others around here. check them out if possible and see which ones best. cheers
http://www.caraudiodirect.co.uk/prod...oducts_id=4904
http://www.caraudiodirect.co.uk/prod...oducts_id=4814
Old 05-31-2006, 09:59 AM   #6
_
RedGTiVR6 has a spectacular aura aboutRedGTiVR6 has a spectacular aura aboutRedGTiVR6 has a spectacular aura about
blowchunks!
hahaha
go for it
for that kind of a budget, just don't expect to get anything good.
Id go with the Type S stuff from alpine before ANYTHING from blowchunks
Jan Bennett
RedGTiVR6 is offline   Reply With Quote
anybody have the monsoon audio system in their volkswagon? Crazy_Cyrax Car Audio 12 10-24-2006 03:34 PM
FS: Award winning Car Audio system RedGTiVR6 Classified Archive 4 09-01-2005 08:37 AM
Couple of questions about the monsoon system Bugbyte Car Audio 5 07-07-2005 08:47 PM
Audio problems, Epia Sound, and FAQ stuff gothate Newbie 2 06-16-2005 05:04 PM
Connect hand held MP3 player to car audio system? jasonwood General Hardware Discussion 3 10-31-2001 12:30 AM
