Old 05-31-2006, 07:43 AM   #1
rollingclean is on a distinguished road
Stuck with a blown speaker.
I have a 1996 Toyota Windom 3.0 G (Lexus ES300). The rear speaker(subwoofer) is blown and I want to replace it. I don't know the exact size of the speaker but I'm guessing it's an 8inch. I've looked at the bottom of the speaker and it says 2ohms, so I've been looking online for 2ohm 8inch subs but I only find dual voice coil 4 ohm. I've also read that when configured in parallel the 4 ohm would be a 2 ohm. How do I do that. Can anyone help me on the size and ohm I need?
rollingclean is offline   Reply With Quote
Old 05-31-2006, 07:47 AM   #2
_
RedGTiVR6 has a spectacular aura aboutRedGTiVR6 has a spectacular aura aboutRedGTiVR6 has a spectacular aura about
chances are your stock amp won't put out near enough power for any aftermarket sub
Jan Bennett
RedGTiVR6 is offline   Reply With Quote
Old 06-02-2006, 04:15 AM   #3
snoopdan's Avatar
snoopdan is on a distinguished road
This really isnt a car audio forum here, its more for people who have carputers and audio systems intereacted with them, you might want to try the car audio fourm in my signature for some advice.
MECA Car Audio Judge
snoopdan is offline   Reply With Quote
Old 06-02-2006, 09:12 AM   #4
Will Albers is on a distinguished road
You will need to replace it with the same speaker. Check on lexus forums. They are a specific design, with a specific enclosure spec and sensitivity. Using an aftermarket will not produce the same results.
You can try to find an ultra high efficiency sub and new enclosure but for what? Seems like it would just be easier to replace the stock.
Will Albers is offline   Reply With Quote
Speaker Blown??? 3onDubs Car Audio 17 03-10-2006 12:55 PM
Self Amplified Center Speaker? c0rrupti0n Car Audio 4 11-18-2005 11:26 PM
center channel speaker underpowered? 00christian00 Car Audio 18 07-15-2005 01:32 PM
Blown Speaker, How to prevent. WebDog Car Audio 27 04-11-2005 01:43 PM
car amp with default speakers? 273BeLow Car Audio 51 03-30-2005 12:53 AM
