Old 06-11-2006, 03:39 AM   #1
Philhop's Avatar
Philhop is on a distinguished road
Onboard sound crackling DC-DC
Hi , I have a problem that im getting weird sounds using onboard sound on my epia 13000 causing cracklng and whininy noise car is stationary , any ideas? im using a dc-dc psu will a external sounds card solve this , also I still get a thump with a m1-atx
Philhop is offline   Reply With Quote
Old 06-12-2006, 01:04 PM   #2
_
RedGTiVR6 has a spectacular aura aboutRedGTiVR6 has a spectacular aura aboutRedGTiVR6 has a spectacular aura about
do you know what alternator whine is? or engine noise?
does it sound like any of these?
are you running aftermarket amplifiers? are you running the stock sound system?
having all of this information is kind of critical to being able to help you out here.
Jan Bennett
RedGTiVR6 is offline   Reply With Quote
Old 06-12-2006, 05:07 PM   #3
Philhop's Avatar
I know what they sound like it isnt alternator whine , as the car is off or engine noise , i think it might be a bad ground for the computer so i might try another ground after my m1 is fixed
Many thanks
Old 06-12-2006, 05:48 PM   #4
_
please let us know if grounding the PC helps at all.
good luck!
Jan Bennett
Old 06-12-2006, 05:58 PM   #5
Philhop's Avatar
1et you know in 3 days
Old 06-12-2006, 07:09 PM   #6
_
3 days?
why so long? we can't wait that long!
hehe
Jan Bennett
Old 06-12-2006, 07:58 PM   #7
Philhop's Avatar
MY M1-atx Blew up waiting for a replacement hold on!
Haha
Old 06-14-2006, 02:21 AM   #8
ppgt94's Avatar
ppgt94
You may already know this but I'll offer some tips, just in case. Make sure to get a good metal-metal connection. So sand down any paint at the grounding point and I recommend the use of star washers, too. Use the same guage wire as you did for your 12v+ and keep it under 16" in length.
I had a problem with weird noises, clicks, hdd/cd-rom spinning, etc through the speakers for a long time. Finally last week I added a good ground to my case (near the sound card - not sure if this makes a difference or not) and I'm amazed at how clean the sound is now.
Let us know how it goes.
ppgt94 is offline   Reply With Quote
Old 06-14-2006, 02:23 AM   #9
Philhop's Avatar
Thanks for that tip , Im going to screw the case through the floor in the car so that should ground it and then the negitive wire im going under the front seat with the tips that you said
Old 06-14-2006, 02:25 AM   #10
Unregistered User
ODYSSEY's Avatar
ODYSSEY has a brilliant futureODYSSEY has a brilliant futureODYSSEY has a brilliant futureODYSSEY has a brilliant futureODYSSEY has a brilliant futureODYSSEY has a brilliant futureODYSSEY has a brilliant futureODYSSEY has a brilliant futureODYSSEY has a brilliant futureODYSSEY has a brilliant futureODYSSEY has a brilliant future
Have you tried muting different audio sources?
ODYSSEY
Quote: Originally Posted by Tidder View Post
Digital-Car UK|
(\__/)
(")_(")
ODYSSEY is offline   Reply With Quote
Old 06-14-2006, 08:54 AM   #11
_
are you going to remove carpet and paint when you do this?
the small amount of contact that the screw makes isn't nearly enough to be considered a good ground.
Also, by going under the seat - what are you going to ground to? a seat bolt? If so, I suggest THROUGHLY cleaning every bit of paint, gunk, etc out of the threads on both the bolt and the hole.
Good luck!
Jan Bennett
Old 06-19-2006, 05:05 PM   #12
Philhop's Avatar
Success NO NOISE! Grounded under the front seat and whola theres alot of noise running through my cars power lol
Old 06-19-2006, 05:06 PM   #13
_
there's a lot of noise running through all cars power...heh
glad you got it all worked out!
Jan Bennett
Old 06-19-2006, 05:16 PM   #14
Philhop's Avatar
Its funny like I plug my ipod charger in and theres noise all kinda random things like that , now im about 80% complete will post pics soon one bad setup , just waiting for replacement harddrive
Old 06-25-2006, 05:03 PM   #15
Philhop's Avatar
Moved pc to trunk , great ground location using a external soundcard linked to a line driver and complete success no noise! Grounding is the key
FS: USB Sound Blast Live 24 bit & Pioneer 4 Channel 300watt amp clean customs Classified Archive 0 05-21-2005 11:04 AM
Need advice on which sound card to use mtmsol General Hardware Discussion 2 06-22-2001 01:39 PM
hotdeal on microatx motherboard that come with sound and video onboard noproblem General Hardware Discussion 0 07-06-2000 04:26 PM
9.5" LCD from allelec.com & motherboard w/ onboard sound mjohnson General Hardware Discussion 6 03-05-2000 07:36 AM
New sound cards w/ onboard decoding alecl General Hardware Discussion 6 10-06-1999 06:27 PM
