Notices
Old 06-13-2006, 01:26 PM   #1
FM Radio Antenna Help
I just installed a Pioneer Avic-D1 into my Subaru Impreza.
Since then i have lost 2 FM channels and my other usually stron channels flicker as if they are about to die.
is there something i can add to the receiver to make my Radio signals stronger. it used to work perfectly with my stock radio, i dont understand how it decreases once i upgrade my system.
Anyone have an idea of what i can do?
dan8304 is offline   Reply With Quote
Old 06-13-2006, 02:57 PM   #2
Neither darque nor pervert
DarquePervert's Avatar
There are antenna amplifiers available that should help your reception.
Check at a car stereo shop, either locally or online.
SEARCH: It's how information gets found!
How To Ask Questions The Smart Way
My Worklog
Old 06-13-2006, 04:52 PM   #3
_
did you purchase an antenna adapter?
nearly EVERY aftermarket radio requires an antenna adapter to adapt the stock antenna to the aftermarket radio.
Jan Bennett
PLEASE do NOT PM/Email/IM me asking me to spoon feed you. Please post on the forums! Chances are, someone else has or will have the same questions.
RedGTiVR6 is offline   Reply With Quote
Old 06-14-2006, 04:07 PM   #4
i did not purchase an adapter, where can i get one? Ebay?
if so, what the link,
You think Best buy has them for sale?
If so, anybody know if it is easy to install?
Old 06-14-2006, 04:34 PM   #5
_
did a bit of research and your vehicle does not need one
did the stock antenna just plug right into the unit? do you remember?
I will not do the searching for you and hand you the link on a silver platter however. That you need to do on your own.
Jan Bennett
Old 06-14-2006, 05:07 PM   #6
why not? can u give me a hint?is it on this site? another?
i dont get it, you researched but you cant paste the link?
if u can, it would be much appreciated!!
Old 06-14-2006, 05:11 PM   #7
_
wtf?
now you are begging to be spoon fed?
I did a bit of my own research by contacting my own people.
I went out of my way for you in that bit, and now you're practically begging me to hand you all of the information you need on a platter?
I already answered that part of the question for you!
Jan Bennett
Old 06-14-2006, 05:13 PM   #8
thanks
Old 06-14-2006, 06:20 PM   #9
i found this website because i was searching for things like this.
I wouldnt of asked the question if i wouldn't of searched!
OBVIOUSLY, i need help, and this website is made to help people am i wrong?
if ANYONE else has any ideas, they would be a great help!
Old 06-27-2006, 11:50 AM   #10
Can anyone please help me, i've been searching for so long, and its starting to discourage me
Old 06-27-2006, 12:26 PM   #11
Legarcondemerde's Avatar
Newer Subarus require that you connect the blue wire in the harness to turn on the factory antenna amplifier. Connect this and your problems should be solved.
Legarcondemerde is offline   Reply With Quote
Old 06-27-2006, 02:27 PM   #12
Antenna amplifiers amplify everything, even noise. I'd advise against them.
The Subaru does use a digitally amplified antenna and Legarguy is right. You've gotta hook up the power antenna wire to it.
Shadow is offline   Reply With Quote
Radioshark to Car Antenna theminor Car Audio 50 10-04-2007 06:15 AM
lengthening fm transmittor antenna wire hand General Hardware Discussion 2 03-24-2005 11:21 PM
Fm Radio vicky_obee Media Engine 9 07-01-2004 11:52 PM
FM Radio and Cell Phone brrman Car Audio 15 05-14-2004 04:51 PM
FM radio Question thepogcbr900rr General Hardware Discussion 5 05-09-2004 07:27 PM
