Quote:
We would need to leave it at volume 12 i think on the HU, unless we could disable the function that kicks it to 12 each time it is powered on.
your unit kicks the volume to 12 everytime its turned on?? mine stays at the level you left it when the car was shut off...
yes ive tried using it with the face plate off. i bought my car used, and the tape slot had some sticky stuff keeping the little door down, so i took the faceplate off to clean that all up. when i pulled it off i forgot the radio was still on and it still played music haha.
it would only need to be pushed back about 2 inches at most. just the thickness of the screen. and im 80% sure there is enough room. haha.
mounting the screen in that Metra kit is a great idea. on my last car i made a face plate type thing out of plexi, and that was a PAIN. it looked good but took forever to make haha. so i will definitely be using the Metra kit on my next install. im not exactly sure how it would all fit together. but im sure there is enough space up there to fit the screen and the HU. im a firm believer in where theres a will theres a way, especially when it comes to building something. i think im going to be going this route with my install (atleast at first hehe) but ill keep posted to see what descisions/route you choose to go.
@puffanug: i had a computer installed in my 2000 a4, but i rolled/totalled it in early march. luckily i was able to get all of my parts out though! ive picked up a 2003 a4 and im about to order the metra kit and ill be starting a worklog once its under way. im glad to find someone else at the same stage of install as i am. should be fun. im keeping an eye on your worklog as well. you should probably post some progress before the whores take it over! haha. (motivation)
