The MP3car.com Store
Thread Tools Display Modes
Old 06-16-2006, 12:32 AM   #1
Vehicle: 2005 Honda Civic
My Photos: (0)
Which side of the distribution block should the inline fuse be?
Should I put the inline fuse for the amps on each amp power wire going into the distribution block, or just one on the other side going to the battery?
Basically I plan on running 8 gauge from the battery to the distribution block and then another two 8 gauge from the distribution block to the amps. And somewhere in there I'd squeeze the 18 gauge power wire for the computer. Any problems here?
Ampie Case
2.5" Hard Drive 80GB Toshiba 5400rpm
Kingston 512 MB DDR RAM PC3200
Xenarc 700TSV - VGA Monitor
VIA EPIA M10000 Mini-ITX Mainboard
M1-ATX 90 Watt - Smart Power Supply
2005 Honda Civic
Maheriano is offline   Reply With Quote
Sponsored Links
Old 06-16-2006, 12:50 AM   #2
Fusion Brain Creator
2k1Toaster's CarPC Specs
2k1Toaster's Avatar
Vehicle: 2001 Honda Civic EX Coupe
My Photos: (1)
I would put a big one one the main line close to the battery. And then a fuse for each "accessory" on the power distributor, close to the distributor. That way if 1 thing is bad, the individual fuse blows, and if something catastrophically bad happens, then the big one blows. Always good to have a contingency plan too, so 2 fuses essentially to each device is good, in my opinion.
Old 06-16-2006, 05:52 AM   #3
bob^'s Avatar
Vehicle: Ford Falcon XR6
My Photos: (0)
Not to mention the smaller cables comming out of the distro block have a lower current rating. Whilst you might have a 250amp fuse near the battery which is fine for the main cable, 4 guage would melt with less than 250 amps I'd say, and you can see where that would lead to.
2004 Ford Falcon XR6
bob^ is offline   Reply With Quote
Old 06-16-2006, 06:03 AM   #4
hunterius's Avatar
Vehicle: 94 Pontiac Firebird
My Photos: (0)
250A fuse will stand even starter
anyway one big fuse on main cable max. 30cm ( 1 feet) from battery and if you will notable lower cross-section of wires running from distribution block it is definitely good idea put smaller fuses on each wire right behind the block.
"We cannot solve our problems with the same thinking we used when we created them."
AE
hunterius is offline   Reply With Quote
Old 06-16-2006, 08:31 AM   #5
My Photos: (0)
So what size fuses do you think I need for these?
computer
120 watt 4 channel amp
250 watt mono amp
Ampie Case
2005 Honda Civic
Old 06-16-2006, 08:48 AM   #6
hunterius's Avatar
My Photos: (0)
there is simple formula : wattage peak + 10%
if your numbers is peak so let say:
-main source 90 - 100A fuse
if your wires from distr. block is short enough , apms and PSU has its own fuse, so you don't need any other fuses. But I think that your 8awg wire from battery to block is insufficient ...you need 4awg.
and here is recommended maximum fuse for vary wires
00 awg 400 amps
0 awg 325 amps
1 awg 250 amps
2 awg 200 amps
4 awg 125 amps
6 awg 80 amps
8 awg 50 amps
10 awg 30 amps
12 awg 20 amps
14 awg 15 amps
16 awg 7.5 amps
and here http://www.bcae1.com/wire.htm you can find a lot of information you need
AE
Old 06-16-2006, 09:24 AM   #7
My Photos: (0)
Okay, so here's my plan of attack then.
4 gauge wiring from battery to distribution block in trunk.
125 amp fuse in this wire near battery.
8 gauge wiring from 250 watt mono amp to distribution block with 50 amp fuse.
8 gauge wiring from 120 watt 4 channel amp to distribution block with 50 amp fuse.
Computer power wire to......????
Ampie Case
2005 Honda Civic
Old 06-16-2006, 09:29 AM   #8
hunterius's Avatar
My Photos: (0)
how long will be wire from block to amp?
for carputer you need wire rated for at least 10A ( I am not familiar with awg sizes 'cause I'm from europe but I think 14awg will be enough )
AE
Old 06-16-2006, 10:16 AM   #9
My Photos: (0)
The amps and computer will be in the trunk and I guess I can put the distribution block anywhere it needs to be. I was thinking about the trunk to cut down on the length of wire from the amps to block.
Ampie Case
2005 Honda Civic
Old 06-16-2006, 10:20 AM   #10
hunterius's Avatar
My Photos: (0)
so once again
if your wires from distr. block is short enough (about 2feet) , apms and PSU has its own fuse, so you don't need any other fuses put to wire.
AE
Sponsored Links
Old 06-16-2006, 11:07 AM   #11
My Photos: (0)
So no inline fuse from amps to block? Is that safe? Sorry, I just need to be explained how the length of wire matters. I'll check the site you posted as well to see if it's there.
Ampie Case
2005 Honda Civic
Old 06-16-2006, 11:19 AM   #12
hunterius's Avatar
My Photos: (0)
I think it is safe 'cause shorten wire is less possibility of accident and little sparkling and short wire even thin is able blow main fuse without melting.
AE
Sponsored Links
vB code is On
Trackbacks are Off
FAQ: How to Wire an OPUS PSU Quattro The FAQ Emporium 74 08-26-2006 12:38 PM
Distribution Block Questions beckkl Power Supplies 5 10-20-2004 11:29 AM
Power Supply Connections nick9871 Power Supplies 44 07-12-2004 06:25 PM
quick fuse question.... jusatry General Hardware Discussion 2 02-23-2004 10:54 PM
What size fuse should I use on distribution block going to Opus power supply? smoldyr Power Supplies 5 01-07-2004 11:38 PM
Sponsored Links
SEO by vBSEO 3.1.0
Ad Management by RedTyger
