Old 06-30-2006, 05:33 PM   #1
LiquidKernel's Avatar
Simple Remote Turn on Delay
Since my OPUS turned on the amp 30 seconds after being powered on, I decided to build a simple 555 timer that would turn on my amp after 12 seconds.
It can be built on a little proto PCB using spare parts (I had everything already in my parts bins), or for around $8 using Radio Shack parts.
Hook up the plus to ACC/RUN/START (that way it doesn't restart when you crank), the negative to ground and the output to your amp's remote line, and viola!
My capacitor (C) and resistor (Ra) values were: 100uF and 100k. Which is about 11 seconds.
http://555-timer.clarkson-uk.com/operation/frames3.html
95 Volvo 850 T5 • Konis • ECU @ 17psi • 5+20% Tint • Orange Ambient-Light + LED Dash Lights • DigiMotive Dimmer • Custom LED Brake Lights • 2.5" BOSCH HID Projector Retrofit
Carpc: [▓▓▓▓▓▓▓] 99% Cleanup.
LiquidKernel is offline   Reply With Quote
Old 06-30-2006, 10:14 PM   #2
cool!
Will Albers is offline   Reply With Quote
Old 07-13-2006, 10:09 PM   #3
Excellent work!!
Just built one myself and worked great!! I made it with a 45 sec delay and added a relay so it would work with 2 amps. Thanks for the help.
fronzt is offline   Reply With Quote
Turn your computer on by remote control PaulzY General Hardware Discussion 22 03-02-2005 02:06 PM
Can Opus 90W remote turn on AMP and LCD > Gibbon Power Supplies 2 10-16-2004 08:57 AM
Remote turn on lead? (Super Noob) Cosine Power Supplies 18 09-02-2004 04:55 PM
ME 2.0 Official Bug Reports phat_bastard ME Archive 67 01-31-2004 06:27 PM
remote turn on lead from headunit to power up PC BluCivic93 General Hardware Discussion 3 07-27-2000 02:13 PM
