Quote: Originally Posted by Shadow
Underimpedance. What subwoofers are you using and what amp? Most 2-channel amps are only stable at 4 ohm mono (2 ohm stereo). Running the amp lower than this causes it to draw too much current and it goes into protection mode.
I have two 10 inch audiobahns. Specs for my subs:
>4-ohm stereo impedance (2 sets of terminals)
>frequency response: 24-1,000 Hz
>recommended power range: 100-600 watts RMS (300 watts per woofer)
And I have a 600 watt lanzar vibe 4 channel amp. Specs for my amp:
>4 x 100 Watts RMS at 4 Ohms
>4 x 200 Watts Max at 4 Ohms
>2 x 400 Watts Max at 4 Ohms Bridged
>4 x 175 Watts at 2 Ohms
>Electronic Crossover Network
>Bridgeable at 4 Ohms
>2 Ohm Stereo Stable
>Tri-Mode Capable
>Frequency Response:15 Hz-35 kHz
I have the first two channels going to the first sub and then channels 3/4 going to the second sub.
Also my amp is not overheating because it s never hot to the touch. And how could it overheat say first thing in the morning when my amp doesnt want to start up right away? My amp is only pushing the two subs, no other speakers. I have suspected the amp turn on wire before, but it has a solid connection and isnt lose. The amp turn on wire is the skinny blue one right?
