Sound Blaster Audigy vs Equalizer
well after a lot of reading, many members recommend to use an equalizer, with the sound card.
Well if you look at the SoundBlaster for example, it has 3 stereo lines out
front/rear/sub, most of the equalizers just get the stereo and sdtribute them to the identical channels.
questions is that worth getting one, or if i actually use standard audio card 3 outputs, and use digital computer equalizer, rather than an analog one
In my case it's simpler to hook up front/rear channels to the 4 channel amp, and sub, to the mono subwoofer amp, and since i will be using digital equalizer, i would not have to worry about placement and wiring of the analog one
Thanks,
Yev
R. T. F. M
