07-16-2006, 05:44 PM
#1
sub wiring question
I've been asking a lot of questions on matching subs and amps lately, and I just want to clarify some questions i've had
if i had an amp that outputs 600watts bridged @2 ohms...if i wire 2 4-ohm subs in parallel, to drop their impedance to 2 ohms...would i be able to wire them on the single channel thats bridged? and if so, does that mean each sub gets 600 watts? or is it half to each?
07-16-2006, 05:49 PM
#2
_
all but the each sub getting 600 watts is correct.
07-16-2006, 06:04 PM
#3
*sigh* I feel like i'm going around in circles with the sub/amp selection, but I appreciate your help with all my questions Red, Thank you, you've cleared up a lot of questions I have had, now I just have to apply what I've learned. Thank you again.
07-16-2006, 06:10 PM
#4
_
you'll keep going around, just make your decision, and realize that this probably wont be the last time you make a purchase, just realize this and remember what you can for the next time.
07-16-2006, 07:00 PM
#5
so if i have 2x 8-ohm subs (DVC)...i can wire them, to get a 2-ohm load, then get 600/2, so 300watts per sub?
and a side question, are DVC's in the same series of subs usually higher quality (in general, i know there are always excpetions) in like the rockford/pioneer/alpine classes?
07-16-2006, 07:02 PM
#6
_
no - you said 2 8 ohm subs in your first post....
they are no different, they are only for different applications.
07-16-2006, 07:14 PM
#7
sorry, yea i know they're different in the posts, the reason is, I was looking at rockford fosgates wiring wizard, and if i get 2x DVC 4-ohm, it only has 1ohm and 4 ohm applications, and I dont think my p6002 would be stable at 1-ohm, and 4 ohm would only give me 150x2, so i'm assuming if i get 2x DVC at 8-ohm, I can get it wired to 2-ohms, and thus getting the bridged 600watts, so 300w per sub...
so I'm assuming my options for DVC subs are either 1x 4-ohm, so i can wire it to 2ohm and get 600watts for a single sub
or
2x 8-ohm, wire them to get 2ohm, and get 300watts each
and a SVC, i could get 2x 2-ohm sub and get stereo 300watts each (300w x2 @2ohm), or 2x 4-ohm in parallel, and get the bridged for 300watts each again...
i'm posting this here, cuz its easier for me to think it through when i'm typing it out, i'm just trying to verify my research and see if its accurate, because none of my friends or family know anything about car audio, and working at best buy, I know the installers aren't the most knowledgable either.
07-16-2006, 07:21 PM
#8
_
600 watts at how many ohms?
07-16-2006, 07:27 PM
#9
when bridged, its 600watts @ 2-ohms (rated) on my "birth sheet (actual rating)" its like 699watts, but i'm just gonna stick to 600 for the sake of my mental capacity.
07-16-2006, 07:31 PM
#10
wait, no...crap crap crap, its 4-ohms, i just double checked, *sigh* you're right...600 watts at 4-ohms bridged...
07-16-2006, 07:33 PM
#11
well luckily, this makes a lot more sense now...thanks for making me double check red, lol
07-16-2006, 07:35 PM
#12
_
lol - glad I could be of some assistance...heh
07-17-2006, 10:06 AM
#13
if i wire my subs like this...
would it be a proper way to do it? the thing thats throwing me off is the wiring the + and - of the coils together...so I dont know exactly what thats doing, and if I do it that way, would it not be to the subs full potential?
07-17-2006, 10:31 AM
#14
and would it be bad to run a rockford amp at full gain? to get the max amount of watts? or is it better to bring it down a notch?
07-17-2006, 10:41 AM
#15
_
you should never run an amp at full gain. there's no sense in it. Usually at that point you will be producing a lot of distortion and will damage your equipment.
If you're running two (2) 4 ohm DVC subs and your amp is as we talked about earlier (bridges at 4 ohms it will put out 600 watts), then yes, that's correct.
Don't worry about wiring the + and - coils together, it's not going to cause any problems, as long as you do it as the diagram suggests.
| Thread Tools |
| Display Modes |
Linear Mode
