Old 07-16-2006, 06:59 PM   #1
Philhop's Avatar
Philhop is on a distinguished road
RE XXX Subs Amp Strapping Howto? 1Ohm?
Hi Guys, Hopefully some one has done this in the past , I have two Caliber 2000D Amps and 2 x RE XXX Subs 2ohm Dual Voice Coil It says for amp strapping 2ohms minimum impedance for CA2000D Plus when strapped does this meen I cant goto one Ohms on each sub? I currently run with one amp at one Ohm for both subs. But I want more power so Strapping amps seems like a valid Idea the amp specs are
2 Ohms 750W RMS
1 Ohms 1250W RMS
Each sub is rated at 1400 W RMS so you can see why I would want one ohm through each of the subs.
Any Ideas?
my TURBO! Altezza!
ATEZZA / IS200 3SGE-TURBO 6SPD MANUAL , EPIA 13000, 512 RAM W/LAN , 100GIG , GPS , TOUCH, 3X LCD, FLUSH TOUCHPAD MOUSE, SOUNDBLASTER EXTERNAL
Philhop is offline   Reply With Quote
Old 07-16-2006, 07:05 PM   #2
_
RedGTiVR6 has a spectacular aura aboutRedGTiVR6 has a spectacular aura aboutRedGTiVR6 has a spectacular aura about
hu!?
amp strapping?
what is that?
and I'm not understanding your post very well either. Possibly try hitting the enter key to separate your thoughts and maybe using punctuation?
btw - I hope you've beefed up the rest of your electrical system.
Jan Bennett
RedGTiVR6 is offline   Reply With Quote
Old 07-16-2006, 07:07 PM   #3
Neither darque nor pervert
DarquePervert's Avatar
DarquePervert is a glorious beacon of lightDarquePervert is a glorious beacon of lightDarquePervert is a glorious beacon of lightDarquePervert is a glorious beacon of lightDarquePervert is a glorious beacon of light
Bridging amps, perhaps?
LOOKING FOR THE FAQ? IT'S HERE.
You never found that link, did you? Why? It's hard to find in the NavBar across the top of the forums, amongst a lot of other crap.
TELL MP3CAR YOU WANT A LINK TO THE FAQ IN A MORE OBVIOUS, NOTICABLE LOCATION HERE.
Old 07-16-2006, 07:09 PM   #4
Philhop's Avatar
Sorry About some of my posts I have a tendancy to rush things -
Hmmm I have a yellow top Optima, May need a HO Alternator soon
120A electrical Draw at the moment.
Amp Strapping - Some amps are capable of being strapped together to provide twice the power. Only like models can be strapped together.
http://www.eaudio.co.nz/CA2000Dplus_...no_graphic.pdf
my TURBO! Altezza!
Old 07-16-2006, 07:11 PM   #5
pancit175 is on a distinguished road
you may even consider using multiple batteries
PROGRESS:
pancit175 is offline   Reply With Quote
Old 07-16-2006, 07:13 PM   #6
_
ok - now I understand what you mean by amp strapping, must be a European term..lol
many amps out there now can be linked together to provide enough power to arc weld with....lovely stuff really.
Jan Bennett
Old 07-16-2006, 07:16 PM   #7
Philhop's Avatar
55 Amp hour battery last about 20 mins on full system crank, Why would I need another battery.
Im not getting into that I might even throw a Few Caps in at some stage.
If from New Zealand lol
Red I dont realy want to Arc Weld anything.
I want a Diagram of How to wire my dual Voice coils with two amps linked
my TURBO! Altezza!
Old 07-16-2006, 07:17 PM   #8
_
from reading the owners manual, it sounds like you can't get 1ohm out of the two amps linked together.
1 ohm stable as an individual amp, but no less than 2 ohm when linked.
the amps are 1 ohm stable.
Your subs can be wired up to be a 1 ohm load.
why do you need to link the two amps to get enough power when the amps put out 1250 watts at 1 ohm?
Jan Bennett
Old 07-16-2006, 07:19 PM   #9
Philhop's Avatar
It says minimum 2ohms so would 1Ohm be less than that or would the minumim of 2ohms be 4ohms bloody confusing!
my TURBO! Altezza!
Old 07-16-2006, 07:26 PM   #10
Extra batteries are just a suggestion. Arguable additional batteries are more efficient than caps. Sometimes cheaper than a whole rack of caps
PROGRESS:
Old 07-16-2006, 07:27 PM   #11
Philhop's Avatar
Pancit175 I agree. Arguable lol
my TURBO! Altezza!
Old 07-16-2006, 07:29 PM   #12
yeah comparing caps vs batteries is trying to compare coke vs pepsi
PROGRESS:
Old 07-16-2006, 07:32 PM   #13
Philhop's Avatar
Which one is coke? I like coke better than pepsi
my TURBO! Altezza!
Old 07-16-2006, 07:34 PM   #14
_
additional batteries will do more than additional caps...for less money.
caps are pretty much useless unless we're talking about the multi farad caps
Jan Bennett
Old 07-16-2006, 07:37 PM   #15
Philhop's Avatar
I was thinking 100 Farad , If I put one Sub on one amp would this meen I get 2ohms aswell
my TURBO! Altezza!
PC Motherboard to 1 amp or 2? hanzacra General Hardware Discussion 5 11-27-2007 03:41 AM
FS: 2 mtx 10 inch subs and 400 watt amp with box xdjxklusivex Classified Archive 0 02-25-2005 04:41 AM
recomend me an AMP. stock speakers, no subs. mattress Car Audio 15 02-05-2005 02:18 AM
F/S: Amp & Subs 89Excess Car Audio 0 04-17-2004 11:50 PM
power? Subs w/ amp Jeffro Power Supplies 4 10-31-2001 12:50 PM
