07-17-2006, 02:47 PM
#1
How can I crimp 0 gauge terminals
I got the 1/0 amp kit from knukonceptz and I cannot crimp the terminals onto the 0 gauge wire... What is the best, least expensive way to do this? I wouldn't mind purchasing a tool from walmart, but I don't know what would work. I've strained my puny biceps trying to get the thing crimped but it won't go!
07-17-2006, 02:54 PM
#2
Bench vise.
07-17-2006, 03:16 PM
#3
I used a heavy pair of pliers (the blunt nose slip-joint type), a hammer, concrete floor, and lots of swearing. I use the pliers to hold it where I want to crimp it, and hammer the jaws against the concrete to close them to crimp.
Gen 1: Pentium 3 1GHz - ATX - 2005
Gen 2: Pentium M 1.6GHz - ITX - 2006
Gen 3: Pentium M 2.0GHz - 5.25" SBC - 2007
Gen 4: (coming soon: Core2 Duo - 3.5" SBC - 2009)
...it never ends
07-17-2006, 03:17 PM
#4
unless you can get hold of a hydraulic crimper then solder them on
07-17-2006, 03:21 PM
#5
Yeah I read somewhere about a vise so I'll look at walmart about those. I think I'll hammer against the ground as the last resort
07-17-2006, 03:24 PM
#6
Those are channel locks, and that method will work, won't be pretty, but it'll work
07-17-2006, 03:45 PM
#8
Well, usually covered by a pretty red or black sleeve, so you're fine. I solder all connections and then cover them in silicone, so I hope it'll last me a while.  It's easier and cheaper than buying specialized tools for a single use:
1) Apply hammer.
2) Repeat as necessary.
...it never ends
07-17-2006, 03:48 PM
#9
Super Moderator. If my typing sucks it's probably because I'm driving....
soldering is probably best, but even then it should be crimped first...
most install suppliers will sell a crimper... it's a block with a slide that you just put the connection in, then slam it with a hammer... there not too expensive, maybe $20-25 & probably worth having if your working with this stuff
07-17-2006, 05:07 PM
#10
_
crimp it one way - as in pushing the two tabs inwards towards the wires. then turn it 90 degrees and fold it all together if you will. then apply solder. You should be golden.
oh yeah - then heat shrink or cover with the rubber covers. Just don't leave it all exposed.
07-17-2006, 05:24 PM
#11
MySQL Error
i've always just used a mini torch and a lot of solder. never crimped before hand... though it would only make the connection more secure
New System in progress:
M10k
Phaze TD1500 ~> Seas g18rnx/p
Zapco Ref 500.1 ~ 12" tc-9
Transflective Xenarc
My Car Pc Install
07-17-2006, 06:38 PM
#12
Well I got the vise from home depot and worked like a charm... well it worked but after lots of force turning the damn thing.. It was only $15 so wasn't a bad investment at all. Thanks again for the help.
07-17-2006, 06:58 PM
#13
I always just used setscrew or compression fittings  A Tweeter up near where I used to work modified some bolt cutters for crimping. Worked incredibly well and you had a ton of leverage so it wasn't a chore.
07-17-2006, 10:33 PM
#14
go with the bench vise they work great
07-17-2006, 11:10 PM
#15
if you want a proper crimp this is what turbo was describing. http://www.theinstallbay.com/i/produ.../IBHDCRIMP.jpg
if you want a good connection without spending the money on a crimper just solder it a cheap torch is only like $10-$15 pliers, vices, and vice grips and channel locks are not the right way to do it however it will work I just wouldn't guarantee the connection.
Aron
Zapco DSP-6
Zapco 500.1-Midbass-X2
Zapco 360.4-Midrange
Zapco 360.4-Tweeters
Zapco 500.1-Sub
| Thread Tools |
| Display Modes |
Linear Mode
