Old 07-17-2006, 04:00 PM   #1
z0l0pht is an unknown quantity at this point
stupid speaker question.
My 96 Civic has 15w nominal, 30w peak speakers in it. I have a pair of Kenwoods that fit nicely, but they're 50w nominal, 250w max. I'm pushing it out of the stock head unit because it sounds fine. What problems will I run into if I swap the speakers? Should I sell them and invest in lower power speakers?
z0l0pht is offline   Reply With Quote
Old 07-17-2006, 04:06 PM   #2
Super Moderator. If my typing sucks it's probably because I'm driving....
turbocad6's Avatar
turbocad6 is a splendid one to beholdturbocad6 is a splendid one to beholdturbocad6 is a splendid one to beholdturbocad6 is a splendid one to beholdturbocad6 is a splendid one to beholdturbocad6 is a splendid one to beholdturbocad6 is a splendid one to beholdturbocad6 is a splendid one to behold
they will probably work ok, & it'll probably sound better than the stock ones, but the speakers won't see there real potential until run with a bit more power...
anything even remotely decent will probably start in the 35-50wrms range... I doubt you'll find anything that is optimised for less that can be considered an upgrade..
they'll be ok...
turbocad6 is offline   Reply With Quote
Old 07-17-2006, 04:17 PM   #3
Does anyone know where I could find information about the stock HU?
Old 07-17-2006, 04:20 PM   #4
Super Moderator & Wal-Mart Greeter
Tidder's Avatar
Tidder has a brilliant futureTidder has a brilliant futureTidder has a brilliant futureTidder has a brilliant futureTidder has a brilliant futureTidder has a brilliant futureTidder has a brilliant futureTidder has a brilliant futureTidder has a brilliant futureTidder has a brilliant futureTidder has a brilliant future
Google?
Tidder
Try RevFE
The best frontend I've ever used, period.
Best Quote EVER!!
Quote: Originally Posted by bramlet View Post
I try to search but I usually only find posts where people ask questions and darquepervert tells them to search.
Tidder is offline   Reply With Quote
Old 07-17-2006, 05:04 PM   #5
MySQL Error
scott_fx's Avatar
scott_fx is on a distinguished road
if you are looking for new speakers then you should look for something that is very efficient. i think infinity is well known for that. (or a horn driver ;-) )
New System in progress:
M10k
Phaze TD1500 ~> Seas g18rnx/p
Zapco Ref 500.1 ~ 12" tc-9
Transflective Xenarc
My Car Pc Install
scott_fx is offline   Reply With Quote
Old 07-17-2006, 05:05 PM   #6
_
RedGTiVR6 has a spectacular aura aboutRedGTiVR6 has a spectacular aura aboutRedGTiVR6 has a spectacular aura about
what kind of information are you looking for on the stock HU?
Jan Bennett
RedGTiVR6 is offline   Reply With Quote
Old 07-17-2006, 07:03 PM   #7
Shadow is on a distinguished road
Replace the stocker with a $150 model if you're not lookin to spend much and you'll get a LOT more out of your aftermarket speakers. Panasonic, Alpine, Pioneer, Clarion are all good brands. For $150 you can even get a good mid-line MP3 deck.
If you've got a keyless entry system you've gotta either relocate the factory radio behind the cupholders in the front and use a T-harness or lose factory keyless.
Shadow is offline   Reply With Quote
Old 07-17-2006, 07:07 PM   #8
volum3rider is on a distinguished road
Huh?......Since when did you have to do this? Is this for certain cars? I have never encountered this.
volum3rider is offline   Reply With Quote
Old 07-17-2006, 09:17 PM   #9
No, that generation Civic is notorious for locating the door lock sensor in the stereo. Mine, fortunately and unfortunately doesn't have keyless entry.
The information I was looking for was regarding the amount of power the stock unit puts out. I'd also like to know if there is a preamp out in the back (though I really doubt it). What keeps me from going and finding out myself is the long procedure for getting into the back of the console; they didn't make it easy with this particular model.
Old 07-17-2006, 09:32 PM   #10
MySQL Error
scott_fx's Avatar
check with pac-audio and see if they sell an interface for that car and year. if they do, then you know you can stop your searching and you also have a solution. usually pac has some sort of adapter to get pre-outs on stock radio's if it's possible
M10k
My Car Pc Install
Old 07-17-2006, 10:05 PM   #11
94-97 Civic with factory installed keyless has the keyless receiver built into the radio.
Old 07-17-2006, 10:20 PM   #12
MySQL Error
scott_fx's Avatar
sooo...since he said he doesn't have keyless...what is the reciever built into?
M10k
My Car Pc Install
Old 07-17-2006, 10:25 PM   #13
94-97 civics need 8 screws removed, and 2 8mm bolts for the radio to be removed. There's no preouts on the radio, you can tag the speakers at the rear deck for use with a line level converter. The stock radio outputs probably on the average of 5-8WRMS
Edit: receiver's built into the little black box that says "Viper" on the outside that's sitting on the shelf at Tweeter.
Old 07-17-2006, 10:30 PM   #14
p&gcustoms is an unknown quantity at this point
most aftermarket radios put out about 15-17wrms so the stock one should atleast put out around 10wrms
p&gcustoms is offline   Reply With Quote
Old 07-17-2006, 10:33 PM   #15
MySQL Error
scott_fx's Avatar
hahaha funny
M10k
My Car Pc Install
Stupid Display Cable Question Chronyx LCD/Display 7 07-15-2004 08:18 PM
Stupid Nano-ITX question... Animepix General Hardware Discussion 3 07-06-2004 05:59 PM
Stupid question about amps Bob0_o Car Audio 10 06-16-2004 08:21 PM
stupid question... What's Cobra? Euclid Software & Software Development 8 11-24-2002 09:29 PM
Stupid question...?again... Meoff General Hardware Discussion 1 06-22-2000 08:09 PM
