Old 07-18-2006, 10:54 AM   #1
k-drive is an unknown quantity at this point
Exclamation 6 speakers in 4 outputs?
This is probably quite a simple question, but...
I have a Blaupunkt Vancouver CD-35 stereo system in my car. The thing has got inputs for only 4 speakers, and currently I have all 4 speakers plugged in: 2 small tweeters, and two smallish general speakers, and they're all in the front of the car.
Now I would like to add 2 more speakers, and I bought a pair of Blaupunkt GTx 92 speakers before I noticed that the system can only fit four speakers... Can I plug the two new speakers in the same connectors (i.e. have four speakers plugged to the connectors of two speakers) without doing damage to the system? If I do a parallel connection, then the impedance will be reduced to 2 ohms, right? Could this do damage to the amplifier?
Also, I find it weird that even though I now have four speakers connected, and the connectors are marked Right Front, Right Rear, Left Front, Left Rear, when I use the fader to fade out the front speakers and only use the "rear" speakers, I can't hear anything at all?!? Physically that's true, as all the speakers now are in the front part of the car, but the fader setting can't know that, can it?
k-drive is offline   Reply With Quote
Advertisement Sponsored links
Old 07-18-2006, 12:48 PM   #2
sdashiki's Avatar
sdashiki is on a distinguished road
tweeters are not full range speakers.
sounds like you have your tweets hooked up to a full range output. thats a no no.
this is more of a carputer forum.
go try an audio forum for better responses.
(----) 0.0%
No more loot for the carpute.
Trying to fit my 20" iMac into the dash... RF 600.5 amp, two 10" JLW0, 8 Infinity Components
sdashiki is offline   Reply With Quote
Old 07-18-2006, 01:26 PM   #3
Yes, I know that very well. And that is why I use high pass filters in between.
Yes, I am aware of that. But since there's a section called 'car audio' here, I thought I'd try my luck here. Obviously I want better responses than yours.
Old 07-18-2006, 01:50 PM   #4
Will Albers is on a distinguished road
Obviously you are not going to get them now.
Will Albers is offline   Reply With Quote
Old 07-18-2006, 01:58 PM   #5
Hey Will, I don't think my original post was in any way offensive, and it's okay if people here can't answer my question. I was put off a bit by sdashiki's reply, and that's why I reacted, but I don't see why you'd need to now reply to the post in that manner. I thought I had asked just a simple question in the original post.
Old 07-18-2006, 02:10 PM   #6
Sdashiki was not being offensive at all, we get car audio centric guys pop in here for 5 posts all the time and then get ticked that we dont answer their question. Sdashiki laid it out to you as we lay it out to everyone else in the same boat. In fact he was much nicer than most of us. He suggested you try other forums as they generally spend more attention on questions like these.
...yet you gave him attitude.
I have your answer. I just don't care to share it with you because of how you reacted after 2 posts on this forum. Learn the social etiquette of a forum before you reply in such ways. Maybe other people will be nicer than me (probably are).
Old 07-18-2006, 02:22 PM   #7
Fair enough.
I asked the question at another forum, and I got an answer right away - without attitude thrown in from either side.
Old 07-18-2006, 02:23 PM   #8
Takes it in the Rear
kevinlekiller's Avatar
kevinlekiller has much to be proud ofkevinlekiller has much to be proud ofkevinlekiller has much to be proud ofkevinlekiller has much to be proud ofkevinlekiller has much to be proud ofkevinlekiller has much to be proud ofkevinlekiller has much to be proud ofkevinlekiller has much to be proud of
Get a 2 channel amp.
Edit: To avoid confusion , plug it to the line out ( the female composite plugs on the back of your head unit)
kevinlekiller is offline   Reply With Quote
FAQ: Why not Home PC speakers for the car? RedGTiVR6 The FAQ Emporium 22 03-05-2008 04:35 PM
92 range rover speakers cutting out MAXXMODDER Car Audio 1 12-09-2005 05:40 PM
Rear speakers not going :( samael Car Audio 9 08-13-2005 03:33 AM
How can I tie two inputs to one amp or 2 amps 2 one speaker ?? microtime Car Audio 25 08-04-2005 12:49 PM
So I have decided to change out my factory speakers for something a little better. lawrence Car Audio 12 10-28-2004 07:44 PM
