Old 07-19-2006, 12:17 PM   #1
SC3005SPD1 is on a distinguished road
Question Umm... how do I power my amps?
I went to a car audio store to get my amps installed and I told the guy that I will be using a carputer instead of the factory hu. Then he asked me how will it power on. That was a good question. How do I power the amps? Im using a laptop and a external sound card.
SC3005SPD1 is offline   Reply With Quote
Advertisement Sponsored links
Old 07-19-2006, 12:21 PM   #2
bay350z is on a distinguished road
I think he means how are you gonna turn on the amps. I use my DC-DC power supply to send the remote turn on.
bay350z is offline   Reply With Quote
Old 07-19-2006, 12:38 PM   #3
Jahntassa's Avatar
Jahntassa is on a distinguished road
I just took a wire off the ACC wire behind the radio, ran it through a switch so I could turn the amps off when I don't want them. That way they'll turn on with the key in ACC, or you can keep them off.
Jahntassa is offline   Reply With Quote
Old 07-19-2006, 12:43 PM   #4
If you use the ACC line, then you might get that thump when the computer boots. The DC-DC has delay to avoid that. It works well for me.
Old 07-19-2006, 12:58 PM   #5
ergman is on a distinguished road
Depending on how he wires his laptop he may not be using a DC-DC PSU. psptibby is right. You will most likely get a thump through out all the speakers connected to the amp when the PC boots. So I would also suggest using the DC-DC PSU with the 20 second delay. If you aren't going that route then use the 12V wire on the ACC side of the key.
ergman is offline   Reply With Quote
Old 07-19-2006, 01:03 PM   #6
3onDubs's Avatar
3onDubs is on a distinguished road
Two options...
1. Find a switched power source in your car that turns on and off when you turn the key. This is also known as an ignition wire. With this setup, you will need a delayer installed so that you don't get that pop sound when your computer boots up. You can get a pop stopper from david navone's website.
2. Use the amp turn on wire off of your power supply. Almost all power supplies have this wire comming out of it. They are usually set to a small delay that will prevent turn on pops.
PostCount++
- SrCsTc's Bezel
- Alpine W200/H701
- ED Nine.2X
- OZ Matrix Elites
- ED Nine.1
- Idmax 12's
3onDubs is offline   Reply With Quote
Old 07-19-2006, 01:50 PM   #7
That could work, but the guys thats gonna install my liliput said they will use that ignition acc power for the screen. So i guess i will have to look into the dc-dc option.
Old 07-19-2006, 01:52 PM   #8
You could slipt the acc line.
Old 07-19-2006, 01:55 PM   #9
Basically I will be running the 2 amps and the liliput. I was told by a guy at compusa that has a carputer to get a .5 farad cap, an inverter, and a surge protector and run everything off there. Then a 1.5 farad for my amps.
Old 07-19-2006, 01:58 PM   #10
Well i doubt the guy has as much experiance with carpc's as guys on here.. I would get a DC-DC ps. You get a lot more features and dont have to mess with a inverter and all that.
Old 07-19-2006, 02:04 PM   #11
I will have to research on the dc-dc.... i thought they were exclusive for pc's not laptops.
Old 07-19-2006, 02:04 PM   #12
MySQL Error
scott_fx's Avatar
scott_fx is on a distinguished road
Quote: Originally Posted by 3onDubs
Two options...
yup...
welcome back dubs. how was the honeymoon?
New System in progress:
M10k
Phaze TD1500 ~> Seas g18rnx/p
Zapco Ref 500.1 ~ 12" tc-9
Transflective Xenarc
My Car Pc Install
scott_fx is offline   Reply With Quote
Old 07-19-2006, 02:06 PM   #13
Didn't realize you where using a laptop. But you could wiring the power button to the dc-dc and probably the power too depends on the power requirment for the laptop.
Old 07-19-2006, 02:12 PM   #14
MySQL Error
scott_fx's Avatar
just wire off the the acc line and put a delay on it to avoid the pop.
M10k
My Car Pc Install
Old 07-19-2006, 02:14 PM   #15
Its a ibm 570e... not a new machine but does the job. It says 16v---3.36A on the bottom of the base
List Of 5.1/optical Amps Canuck Car Audio 144 03-20-2007 01:34 PM
FAQ: How to Wire an OPUS PSU Quattro The FAQ Emporium 74 08-26-2006 01:38 PM
New Mpegbox Power Supply zootjeff Power Supplies 60 09-20-2005 01:32 PM
Amps power up AFTER computer is on and still pops Ascension Car Audio 5 07-16-2005 03:24 AM
getting an odd motherboard to power on karmann Power Supplies 13 11-28-2001 06:27 PM
