The MP3car.com Store
Thread Tools Display Modes
Old 07-19-2006, 01:24 PM   #1
Vehicle: 2004/Acura/RSX
My Photos: (0)
Sub problems still
Hi i had a post a while back about sub rattling. Now i got my new sub an Elemental design 13kv.2 and i still have the same problem. So my old sub was not blown, but im still stuck with this problem. Its not really a rattle. The sound coming from the sub is like when the bass hits, its not clean. Its like staggered. Im thinking its my amp now cause i replaced everything else. Could the crossover on my amp be messed up, its a rockford 2002 model. Had it for about 2 years now.
flyguy7150 is offline   Reply With Quote
Sponsored Links
Old 07-19-2006, 01:35 PM   #2
MySQL Error
scott_fx's CarPC Specs
scott_fx's Avatar
Vehicle: '99 Chevy Corvette -- '01 Volvo S60 t5 --'03 Honda CBR 600RR -- '97 Suzuki GSX-R750
My Photos: (0)
did you use the same box? did you build that box?
New System in progress:
M10k
Phaze TD1500 ~> Seas g18rnx/p
Zapco Ref 500.1 ~ 12" tc-9
Transflective Xenarc
My Car Pc Install
scott_fx is online now   Reply With Quote
Old 07-19-2006, 01:39 PM   #3
My Photos: (0)
yes same box i built, but its sealed and there arent any leaks
Old 07-19-2006, 02:07 PM   #4
My Photos: (0)
ok i started pushing against the sub and now i hear a squishy air sound coming from the sub. Probably around the rim of the sub. I used all 8 screws for the sub, and the rim itself is like a big gasket. Help please
Old 07-19-2006, 08:17 PM   #5
My Photos: (0)
RTV silicone to the rescue! You can either use RTV (DO NOT GET IT ON THE SURROUND) or you can get some thin weatherstripping from HD or Lowe's and stick it on the back of the basket.
Shadow is offline   Reply With Quote
Old 07-19-2006, 11:09 PM   #6
My Photos: (0)
can i use the same silicone i used on the seals of the box?? I used silicone II (black). And just let it dry first? But how will i put it on when i carpet it?
Old 07-20-2006, 12:09 AM   #7
Pok
My Photos: (0)
If you are using very thick carpet, you could be experiencing a leak through the carpet itself.
Can you hear the air come out from all around the sub, or one particular spot?
Pok is offline   Reply With Quote
Old 07-20-2006, 02:09 AM   #8
My Photos: (0)
Ok guys i figured out what is wrong, im using a rockford 2002 amp, 2 channels, i tried the sub with one channel, then the other, one of my channels is making it sound like crap. One is working good and sounds clean, the other is making the distorted bass. Is it time for a new amp?? or can this be fixed?
Old 07-20-2006, 11:42 AM   #9
MySQL Error
scott_fx's Avatar
My Photos: (0)
there is a guy on the pheonix gold forums that fixes amps. you could sing up there and see how much he'd charge to fix it. it may be worth while to just get a new amp though. Elemental Designs has some good amps that are relatively inexpensive.
M10k
My Car Pc Install
Old 07-20-2006, 03:58 PM   #10
My Photos: (0)
yea im looking at the nine.2. Im hoping i can fix this first, cuz i just bought a bunch of other stuff, like hids.
Sponsored Links
Old 07-20-2006, 07:31 PM   #11
My Photos: (0)
Scott, if you're talking about Cade, he's better off not talking to him
Sponsored Links
vB code is On
Trackbacks are Off
Problems installing Girlfriend 1.0... gospeed.racer Off Topic 28 10-18-2005 05:17 PM
Car voltage problems cheerio General MP3Car Discussion 2 08-16-2004 08:01 AM
Dell Inspiron 8200 & Lilliput TS problems? bkpsu LCD/Display 1 08-15-2004 01:55 PM
Setup nearing completion, having all kinds of problems (yeah i did a :search:) therussman2002 General Hardware Discussion 4 06-21-2004 06:09 PM
Shutdown Problems - Troubleshooting Guide brettwmd Power Supplies 0 05-28-2004 11:46 AM
Sponsored Links
SEO by vBSEO 3.1.0
Ad Management by RedTyger
