The antenna cable should run no more than about a foot and a half. The stock one, that is, because I think the antenna is on the driver rear side of the car, right above the amplifier/reciever for the radio. (As said, the stuff up front is only the controls / tape deck)
Really your situation depends on how long the cabling is. It's best to keep the FM connections short as possible, but sometimes that isn't possible. If you can put the FM connections from the Drive & Play in the rear, then put the brain wherever you can put it. Position doesn't really matter.
