Old 07-20-2006, 01:44 PM   #1
supersupra123 is an unknown quantity at this point
Question Alternator help please!!
Hi everyone... I have a US 2000 amp pushing 4 IDQ15s. I have a Optima red top under the hood, a yellow top in the back.
And I was told I need a new aftermaket Alternator. US 2000 amp is 2000 X1 Watts RMS@ 2 ohms and it has a 300 Amps fuse. I have an Eclipse amp for the components with 80 Amps fuse.
Now I need an Alternator, Can I use a 200 Amps alternator, or do I need a 250 amps one? Please help me out... Thank you
supersupra123 is offline   Reply With Quote
Advertisement Sponsored links
Old 07-21-2006, 09:47 AM   #2
_
RedGTiVR6 has a spectacular aura aboutRedGTiVR6 has a spectacular aura aboutRedGTiVR6 has a spectacular aura about
I guess my first question is, what is the stock output of your alternator?
You might be able to have your factory alternator rewound.
If there's not that much of a difference in the price between the 200 and the 250, go with the higher output.
Jan Bennett
RedGTiVR6 is offline   Reply With Quote
