07-20-2006, 02:21 PM
#1
S10 sound system
Just replaced my dash 4x6's with some Pioneers. Made a great difference, but now I need to replace my 4x10's behind the seat. Any suggestions?
Also, I am wanting to install a sub in the long run, but do they make a quality unit that is also compact enough to fit behind my seat? (Standard cab...) If not, what is the best way to go for a sub in the standard cab?
Thanks!
07-20-2006, 08:37 PM
#2
Don't bother replacing those speakers. They're at least $100 for anything decent(retail) and they sound crappy still. Your best bet for good sound is to get a component set and put the mids in the doors and replace the dash speakers with the tweeters (eventually). Your best bet for a sub is a custom built box. I put 4 10s in my brother's regular cab Ranger. Replace your stock bench with buckets from an Integra and you'll gain legroom and you can move the passenger seat up a little to fit a bigger box back there.
07-20-2006, 09:14 PM
#3
There is a universal 4x10" to 6x9" adapter by scosche, part # SA41069, that may or may not work for your application. I'm not making any promices. I've never used them b4
PROGRESS:
07-20-2006, 09:41 PM
#4
It won't work as there's no room to bottom mount them. Those work in the fullsize sedans like the Caprice.
07-20-2006, 10:45 PM
#5
I figured a custom box would be my best bet. As for the 4x10's, anything is better than what I have. They are ****. (One is blown) I found some Pioneers for $80, good deal? As for the subs and box, what would be my best bet for keeping my stock benchseat?
07-21-2006, 08:33 AM
#6
Forget the 4x10s, you'll never hear them with a sub. Just disconnect them and take them out. For the sub, you need a shallow mounting subwoofer. From what I remember working at CC and BB, there's not a whole lot on the retail scene that will help you out. How tall are you?
07-21-2006, 08:40 AM
#7
5'10" tall
07-21-2006, 09:07 AM
#8
_
07-21-2006, 10:26 AM
#9
mount em in the roof!
i've seen a lot done in s10's .. i used to own one myself, a 96 extended cab 4x4, but if you drop the subs low enough in the box and dont get anything MASSIVE you should be able to find enough space back there to get 2 subs and an amp, im 5'7 so im guessin' your seats not all the way back [esp. if its a 5speed]
Carputer Status:MobileOne: retired - via - Gentoo Linux, gps drive, nGhost, tethered e815
MobileTwo: retired - via - Ubuntu Linux, gps drive, nGhost
MobileThree: development - Intel Atom - Gentoo Linux, iGuidance3, navIT, nGhost2 -- worklog--
07-21-2006, 12:17 PM
#10
JL makes a 6.5" sub, so does eD. RE makes a killer little 8" sub too. You could probably get 6-8 8s behind there no problem if you're a basshead.
07-21-2006, 09:48 PM
#11
OK, so how would it sound if I just put in some 4x10's and held off on subs? I am not off for road thumping music, I just want to make it good enough to please those in the vehicle. (ME) My 4x6's, of course, do not have a whole lot of hit to them, but will the 4x10's throw in a little more kick?
07-21-2006, 10:39 PM
#12
Tommorow morning I will get some measurements of what I have to play with behind the bench seat.
07-22-2006, 12:24 PM
#13
Alright, 9.5" behind the seat. At a foot of rise, there is ~6" clearance still, so as long as I get something to fit the depth and lets the sub sit in at a minor angle. Suggestions for a prebuilt? Or am I gonna have to custom build?
07-22-2006, 01:57 PM
#14
Just found an outfit that makes a box for this application.
http://www.shipsound.com/product_inf...ucts_id=101269
Though their site appears to be having some problems, scroll down and to the right and you will find it. Thinking of purchasing this on my next paycheck and grabbing a couple of subs to get it ready. Any good 10" sub and an amp to run them recommendations?
07-22-2006, 05:04 PM
#15
That's a whole bunch of room. Infinity Reference series subs will do you right and you could pick up a V12 or Vpower alpine mono amp.
| Thread Tools |
| Display Modes |
Linear Mode
