Old 07-20-2006, 04:22 PM   #1
sicro is an unknown quantity at this point
Amplifier - overheatig
I have a Magnat amplifier (http://www.car-sound.ro/The_Rock_800-p234.html) used to power 2 SAL speakers which have aprox. 50W rms, wired in paralel with 2 no name tweeters (+4.5 condensators) on 2 chanels and a Dibeisi subwoofer ( i have no ideea how many W it has..max. 150rms ~12inch diameter) in bridged mode.
It seems it doesnt like me very much as it overheats and turns off in aproximately 10-15 minutes of use. When i disconnect the subwoofer, things seem to be fine.
Does this happen because the speakers are too small for this amplifier? Or why?
sicro is offline   Reply With Quote
Old 07-20-2006, 04:49 PM   #2
_
RedGTiVR6 has a spectacular aura aboutRedGTiVR6 has a spectacular aura aboutRedGTiVR6 has a spectacular aura about
I'd venture to bet that you're running the amp at too low of an ohm load.
What are your tweeters rated at? 4 ohms? 6 ohms? 8 ohms?
what are your subs rated at?
also, that amp isn't very powerful, so for you trying to power 2 subs and two tweeters off of it, you might be demanding too much of it.
Jan Bennett
RedGTiVR6 is offline   Reply With Quote
Old 07-20-2006, 04:52 PM   #3
The amp is supposed to be 110 rms / each channel. So i`m running 2 channels which are made up of a 50rms woofer + tweeter and one channel (2 channels bridged) of 250 W rms to power the Subwoofer.
They are all @ 4 ohms.
The wires used to power the amplifier are 8GA.
Old 07-20-2006, 05:22 PM   #4
Could it be that the gain and bass eq are set to high?
Old 07-20-2006, 05:24 PM   #5
_
possible - have you properly tuned your set up?
http://www.350z-tech.com/zwiki/Tutor...plifier_Tuning - follow this link if not.
all sounds to be ok...
I'd check for bad grounds, pinched wire, improper termination techniques, etc.
Jan Bennett
Old 07-21-2006, 10:39 AM   #6
It seems you were right, after resetting the bass eq and the gain it doesnt power off anymore. However, it still gets kind of hot, possibly also due to the low quality speaker. Anyway, problem solved, thanks for your help!
Old 07-21-2006, 10:55 AM   #7
_
glad to hear it's working better now!
let us know if you have any other problems.
Jan Bennett
Recommendations on head unit or amplifier? (for use with a PC in the car) sofakng Car Audio 15 02-15-2006 12:50 AM
Looking for small amplifier Suprapc Car Audio 10 10-05-2005 06:27 AM
Can i use the amplifier cables for car pc? TRONiC Power Supplies 14 04-29-2005 12:41 PM
What I did to to eliminate amplifier turn-on pops lfilomeno Car Audio 2 04-11-2005 08:31 AM
stock ford windstar amplifier? Vchat20 Car Audio 2 02-10-2005 01:46 PM
