Old 07-22-2006, 09:19 AM   #16
red_parchel's Avatar
that looks good, easy, and like it should be a big help! thanks red
[and every one else]
Carputer Status:
MobileOne: Gentoo reinstall/optimization - coming soon!
MobileTwo: ubuntu quick fix while MobileOne's out of service
--worklog--GeekBlog--
Audio: stage 2 nearing completion
red_parchel is offline   Reply With Quote
Old 07-22-2006, 04:18 PM   #17
Mandos's Avatar
Quote: Originally Posted by Red GTi VR6
Just do the big 3 and you should be fine:
http://forum.sounddomain.com/ubb/ult...c;f=5;t=007801
BWAHAHAHAHA
Got you to agree with me
Uhhh....good link.
Sorry...fiberglass fumes.
Chris Schempp
Elemental Designs
Scion tC in progress
Mandos is offline   Reply With Quote
Old 07-22-2006, 11:14 PM   #18
stkdidy ntshidy's Avatar
the big 3!!! i remember that shlt...i learned the basics from that! oh so long ago...
2005 Mustang GT:
12w7...arc audio kar1000.2t...jl 300/4 pushng focal 165k2p...pioneer premier deh-880prs...tm-701l...audiocontrol eqs
want: my stereo actually IN the car
stkdidy ntshidy is offline   Reply With Quote
Old 07-23-2006, 02:45 PM   #19
we all go through it i suppose
Carputer Status:
Old 07-25-2006, 10:08 AM   #20
Thats what I'm doing. I also ordered one of these (see link below) + new wiring, new battery terminals and new terminal connectors.
http://cgi.ebay.com/ebaymotors/ws/eB...RK%3AMEWN%3AIT
I changed my entire system as it is. Running 1/0 gauge to a 135 amp circuit breaker from stinger, to a distribution block which has 3- 4 gauge outputs which will be going to 1 ED mono am, 1 ED 2 channel and possibly another ED 2 channel if there comes a need for it.
If I still have problems, then I plan to upgrade the alternator.
1996 Lexus SC400
1972 Datsun 240Z
1994 Toyota Camry (sold)
Curry is offline   Reply With Quote
Old 07-25-2006, 10:10 AM   #21
You DO realize the price of 3 1farad capacitors = the price of a yellow top. And you can relocate the yellow top directly into the trunk if you'd like....oh, and 3 4ga links is bigger than a single 0/1 gauge link...
LaxPlaya8513 is offline   Reply With Quote
Old 07-25-2006, 10:14 AM   #22
yup! yellow top is on order! ... and i think you might be right about the 3 4awg's .. i dont plan on re-running them, not unless i run into more problems after the "big 3" a battery upgrade, AND an alternator upgrade.
Carputer Status:
Old 07-25-2006, 10:54 AM   #23
The 1/0 can carry almost 3 times the current of a single 4AWG wire. What are you trying to say? The volume of the three cables is higher than a single 1/0?
Shadow is offline   Reply With Quote
Old 07-25-2006, 11:43 AM   #24
wouldnt 3 4awg wires be able to carry the same amount of [or just a LITTLE bit more] current as a single 1/0? ::scratches head::
Carputer Status:
Old 07-25-2006, 12:45 PM   #25
_
considering 1/0 usually has about 1600 strands and 4 has about 400.
though the current carrying capacity of 3 4gua wires may be more than a single 1/0 cable. You'll still have to buy a distro block and fusing for all 3 of theose 4 gua wires, compared to a single for the one 1/0 wire.
Jan Bennett
PLEASE do NOT PM/Email/IM me asking me to spoon feed you. Please post on the forums! Chances are, someone else has or will have the same questions.
RedGTiVR6 is offline   Reply With Quote
Old 07-25-2006, 12:53 PM   #26
XC-C30's Avatar
the answer would be no then.
and I TRUELY hope, red, you didn't sit at an open fireplace in a cold wintersday and counted those strands by hand personaly!
Xenia: pink princess
status:
In progress
STATUS:
'T SQiekenkot: No Car
hardware: 0%
software: 0%
audio: 0%
building: 0%
XC-C30 is offline   Reply With Quote
Old 07-25-2006, 12:57 PM   #27
_
nope - it used to be posted on the stinger site...there's an accepted amount per gauge.
also, keep in mind that a big bundle of 1/0 can't dissipate heat as easily as smaller wire.
there's also capacitance and inductance issues as well.
Jan Bennett
Old 07-25-2006, 01:09 PM   #28
good point red G! using either 1/0 or three 4awg i've got enough juice movin' to the back to power my amps.
is there a problem if i put a block on the end of my 4awg that leads to my component amp, then run 4awg out of it and into my amp, and something much smaller into my car pc? or should i just run another +wire back
Carputer Status:
Old 07-25-2006, 01:10 PM   #29
_
it all depends on how much current the amp draws and the computer.
Jan Bennett
Old 07-25-2006, 01:12 PM   #30
well i guess its time to bust out the meters then
Carputer Status:
Do I need a cap? Maheriano Newbie 25 08-15-2006 11:35 AM
Need to confirm my wiring setup: carpc + cap + amp + subs, etc mattress Power Supplies 3 04-11-2005 02:22 PM
Using a high farad cap to survive engine crank lakorai Power Supplies 6 03-28-2005 09:47 AM
Mastero MK4.5 Parts list Question? 047025n Power Supplies 5 03-16-2005 12:09 AM
Anit-Crank-Drop cap solution? All4Norway Power Supplies 4 01-07-2003 08:20 AM
