The MP3car.com Store
Thread Tools Display Modes
Old 07-20-2006, 11:18 PM   #1
My Photos: (0)
Getting ready to connect everything
I got all my fiberglass done in the trunk, so now I have to rerun all the new power cable etc. I just wanted to make sure everything I'm doing is correct.
1) All the gauges in the diagram are for the power and ground. I didn't show where each thing is grounded too, but I have a good place in the trunk where each ground point will be.
2) For the ignition for my carputer I ran a wire from the cig adapter to the trunk and it powered on the computer fine and also the speaker amp when I had it. It did have the thump when the amp powered on, but I have yet to utilize the anti thump from the M2-ATX. Should I run the anti-thump to just the speaker amp and the sub amp. Then a separate ignition wire for the Audiocontrol, XM Direct and Extra Comp fans?
I appreciate all the help and hope my questions made sense. Thank you.
hornyleprechaun is offline   Reply With Quote
Sponsored Links
Old 07-21-2006, 07:31 AM   #2
My Photos: (0)
I see overkill in your future.
You don't need 10AWG wire for 500W of power. You don't need 10AWG for your signal processor or your XM direct.
Why don't you run a single #12 wire from an accessory wire at the dash and then use a single relay to run 16AWG wire to those two pieces? It'd be much cleaner and it'll save a lot of money.
Oh, if that ovular shape is a cap, you're probably better off without it. Other than those issues, that looks good.
Shadow is offline   Reply With Quote
Old 07-21-2006, 08:14 AM   #3
_
RedGTiVR6's CarPC Specs
Vehicle: VW GTi VR6 / Ducati 900 SS & S4R / Dakota R/T Supercharged
My Photos: (73)
http://www.mp3car.com/vbulletin/showthread.php?t=81339
Jan Bennett
If you're needing someone to tell you what to buy, how to install it, or how to make it sound good, I charge a consulting fee.
RedGTiVR6 is offline   Reply With Quote
Old 07-21-2006, 11:43 AM   #4
My Photos: (0)
So 12 awg for the amp to the sub and then 16 to the audiocontrol and the xm direct?
Old 07-21-2006, 11:57 AM   #5
IntellaWorks's Avatar
Vehicle: 2005 Toyota Tacoma
My Photos: (0)
That sounds better.
Progress [I will seriously never be done!]
Via EPIA MII
512MB RAM
OEM GPS (embedded)
nLite WinXP pro on
1GB Extreme III CF card
Carnetix 1260 startup/ DC-DC regulator
Software: Still, re-Writing my existing front end in .Net
IntellaWorks is offline   Reply With Quote
Old 07-21-2006, 01:15 PM   #6
My Photos: (0)
I'd say 14 or 16 would be fine to the sub. You're really not pushing much power through it at all.
I'm not sure if 16 fits in that stupid little black thing audiocontrol puts on all of their stuff. If it does, go with 16, if not, go with 18.
Old 07-21-2006, 06:27 PM   #7
My Photos: (0)
Sounds great. Thanks again for all the help.
Sponsored Links
vB code is On
Trackbacks are Off
bluetooth GPS wont automaticly connect at startup? chewEboy GPS 0 05-26-2006 10:00 AM
Connect to Internet using GPRS Cellphone & Bluetooth bigjoe22 Wireless Communications 0 04-18-2006 11:17 PM
connect button alti Centrafuse 3 07-31-2005 11:04 PM
Is it safe to connect my inverter directly to the car power outlet? b8bboi Power Supplies 2 07-21-2005 12:07 PM
does NetStumbler actually CONNECT to access points? Grayscale Wireless Communications 71 06-29-2005 05:27 PM
Sponsored Links
SEO by vBSEO 3.1.0
Ad Management by RedTyger
