Ok I have a question...
I had plans to mount my IDMAX in the side pocket of my trunk in a sealed fiberglass enclosure...
I was reffering to this chart...
My question is, if instead of mounting this sub normally in the same sealed enclosure, if I were to reverse mount it in the same enclosure, would this be any different from mounting it the normal way in the box? I believe this would be called using an infinite baffle?
Basically the sub would be mounted like these in this post...
http://mp3car.com/vbulletin/showpost...9&postcount=15
The IDMAX website says it can use an infinte baffle mount.
And if I were to invert the sub the air space in the actual enclosure i built would not matter becuase the sub is using my trunk as the box... correct?
