Notices
Old 07-23-2006, 11:44 AM   #1
NEED AUX IN/PINOUT on my radio! HELP!!
Hello! I just yanked my radio/cd out of my 04 Mitsubishi Lancer. I want to start building a carputer, but need to start with the HU and try to get an AUX in.
This is a single DIN, Model number MN141489 made by Matsu****a. The front has a number P301 on it. The back has a connector that was plugged in, but there is also a DIN jack that was not being used.
Is this something that I could use for AUX in?
Any ideas?
drewbad is offline   Reply With Quote
Old 07-23-2006, 11:52 AM   #2
Takes it in the Rear
kevinlekiller's Avatar
I did a quick google , and theres mostly ebay links to this head unit.
You have 4 or more options :
1: Open the head unit , you might see what each pin do ( they sometimes write it on the pcb).
2. Buy a cd-changer and hack it.
3. Buy a new head unit with aux in ( its not expensive, will look better , will sound better )
4. If your intent is to put a carpc , ditch the head unit , go pc - amp.
kevinlekiller is offline   Reply With Quote
Old 07-23-2006, 11:54 AM   #3
You can also ditch the am or fm or cd , by cutting the traces going to the preamp. Solder wires ; have a gettho aux in.
Old 07-23-2006, 01:13 PM   #4
FC3S's Avatar
i'd agree with either of these, that headunit is
personally, i'd just lose the headunit all together, waste of space/power
FC3S is offline   Reply With Quote
Old 07-23-2006, 03:55 PM   #5
I think I found you a pinout for that connector.
http://carstereohelp.net/wireharness_Mitsubishi3.htm
I found it in this thread on the mitsubishi forums.
http://www.mitsubishi-forums.com/t15...-head-unit.htm
I know that some Subaru's also use panasonic (matsu****a) factory headunits. On some of those cars the audio pins in the 13 pin connector are always passed through to the speakers. That is, whatever signal you put on those audio pins (left,right,ground) will be heard along with whatever else you are listening to (radio, cd). The solution for these decks is to play a "silent cd" while using this input.
I'm not at all sure if you are in this situation, but it's something to try. Personally I would probably open it up too, and see if there are any clues inside.
Good Luck.
walky_talky20 is offline   Reply With Quote
Old 07-24-2006, 11:21 AM   #6
Thank You!!
Very cool, thank you!
Class 2 Data Bus owenjh Engine Management, OBD-II, Engine Diagnostics, etc. 35 10-09-2008 04:34 AM
WinTV Radio won't stop playing... alang Road Runner 2 06-02-2006 01:56 AM
Adding an AUX input to a factory radio ParrotSquawk Car Audio 3 05-29-2006 09:27 PM
TM-701L converted Lilliput causes radio interference archimense LCD/Display 16 07-04-2004 09:14 AM
Fm Radio vicky_obee Media Engine 9 07-01-2004 11:52 PM
