The MP3car.com Store
Thread Tools Display Modes
Old 07-23-2006, 06:47 PM   #1
swe_seifer's Avatar
My Photos: (0)
Question need help, no sound through nano-itx
Hi !!!
i've build a carpc with the epia-n motherboard... everything is working fine except i get no sound, nor any noice through the speakers in car...
i made the case myself and running the onboard ac-97 audio to my car stereo... everything is tested and works fine, sound is playing and no errors inside the comp (newest drivers etc) and it works great... hooking up a laptop to my car stereo and it plays fine through my setup in car
but no sound when i plug my car-stereo to my onboard audio car pc ???
this is getting so annoying... any ideas, help suggestions are welcome
there must be something i've overlooked as i want to test it all before i return it cause of faulty... if anyone haven't had sound and made it work pls post !!!
very many thx
/swe_seifer
swe_seifer is offline   Reply With Quote
Sponsored Links
Old 07-23-2006, 07:06 PM   #2
walstib's CarPC Specs
walstib's Avatar
Vehicle: 2001 Nissan Pathfinder
My Photos: (0)
If you plug headphones into the Nano, do you have sound? I guess you are running Windows, how is output configured? Line out, 5.1, etc.? I have a Nano, but am running Linux and have not had any problems bench testing, but have not completed my car install.
Carputer Project Status:
0% - Mobo died on 2/17/08
Check out the worklog for my '01 Pathfinder.
walstib is offline   Reply With Quote
Old 07-23-2006, 07:35 PM   #3
swe_seifer's Avatar
My Photos: (0)
no sound even with headphones... tested
im running xp sp2 and currently only configured as 2-speakers, using the green jack... no other and no other config problems, everything checked
still no sound... is there a chance any ports should be grounded individually to chassi ??? wild speculations... but seeing it plays fine but not hearing anything leaves me thoughtless... ?!
but way good you have nano too... hard to find these users :P i have another question regarding this board... the frontpanel connector... driving me nuts, i have pwr button cables and power led cables and hdd led cables... all + and -
the manual only says pin 1-12 right ??? and im wondering on which pin should the pwr button + be and its - and pwr_led + and its - and hdd_led its + and - be connected ?
if you tell me your pins you've connected i will be glad to check im on my way... and also have you connected a pc-speaker to your nano ??? wild guess but trying all else i wonder if it has to be connected in order to get the onboard audio to work... thinking ground issues or circuits... pls write again !!!
my specs:
VIA EPIA N 10000 Nano-ITX
512 MB RAM DDR400
SLOT-IN DVD
80 GB SATA HDD
WINXP SP2
BU-353 USB GPS
Custom built case housing it all :P
Old 07-23-2006, 08:57 PM   #4
walstib's Avatar
My Photos: (0)
The plug you should be testing is the one on the left (looking at the back of the board). Not sure of color. From left to right, line-out, line-in, microphone. So it could be a driver issue if you can't get sound at all out of the board. Have you tried changing the setup to four speaker, 5.1, etc. just to test?
If that doesn't work and you have time/resources, download a live Linux ISO and burn it to test sound under Linux. Even a small distro like DSL recognized the equipment and produced sound on my board. It doesn't install anything so it won't hurt your current install.
As for wiring:
HDD LED = 2&4
Power button = 6&8
Power LED = 3&5
Reset button = 10&12
Case speaker should be 11&7 (I think)
I have only used power and reset buttons.
Front Panel Connector:
12 | * | * | 11
10 | * | x | 09
08 | * | * | 07
06 | * | * | 05
04 | * | * | 03
02 | * | * | 01
1 = +5v dual
2 = +5v
3 = +5v dual
4 = HD LED
5 = -PLED
6 = Power Btn
7 = +5v
8 = GND
9 = N/A
10 = Reset Switch
11 = Speaker
12 = GND
I have not tried a case speaker as my board is mounted in my console, no case.
Old 07-24-2006, 08:39 AM   #5
swe_seifer's Avatar
My Photos: (0)
oh i didn't heard of DSL but i will try it asap to see if any sound is heard... i tried a various settings already 2, 4, 5.1 speaker setup and still no sound... lets see if Linux works the sound then i can take it from there, way many thanx for the help so far !!! i will post any result as soon as i know more...
as for the wiring on the case connector im very thankful, cleared it all... i have a setup like that just needed to be sure many thanx on good explanation
will post soon again
/swe_seifer
Old 07-24-2006, 08:54 PM   #6
walstib's Avatar
My Photos: (0)
Cool, let me know how things turn out.
Old 07-31-2006, 08:31 AM   #7
swe_seifer's Avatar
My Photos: (0)
ok here's the finals... i tried DSL and it produced no sound through my onboard connector, either its faulty or im missing something... as i've done my case on my own it might be some grounding issues... as patience flew by pretty quickly i bought an usb-soundcard and it worked like a charm right out of the box though only negative it steals one usb-port...
the computer is almost done, it works and do as i tell her... only missing wifi antennas and extra usb-ports and a top cover... i made the top cover solid and gosh it hot inside !!! need to vent it by cutting up the sides... alt. install a case fan... dont wanna burn this puppy
walstib, your setup is lóoking awesome man... just viewed your worklog keep it up !!! or is it finished by now ???
here's a pic on my carputer...
http://hem.passagen.se/cpskadad/carputer.jpg
http://hem.passagen.se/cpskadad/carput_2.jpg
Old 07-31-2006, 03:45 PM   #8
walstib's Avatar
My Photos: (0)
Bummer about the sound card. Are you going to RMA it?
Still waiting on my harness cable... It should have shipped today. I'm getting impatient! I did get an Atheros minipci wi-fi card with the AR5212A chipset, so I will be installing it and some antenneas soon. I'm wondering how hot my console will get since the HDD will be in the smaller compartment abve with the DVD drive. I may end up routing a tube from my A/C to the console. The rear outputs are directly under the front seats, so it would only be a 2' run.
Old 07-31-2006, 03:47 PM   #9
walstib's Avatar
My Photos: (0)
P.S. swe_seifer, only see white square with red x where your pics should be.
Old 08-01-2006, 03:35 AM   #10
swe_seifer's Avatar
My Photos: (0)
i really should RMA it, but considering it took weeks to get it... i live in Sweden, and sending it back and get a new one... well i should but the wait would kill me will think it over...
and the onboard sound chips aren't the best on market either so i can live with having sound through usb, it doesn't show or anything...
as for you, i've tested it alot... and HDD and DVD is no concern as they produce very little heat, prime concern would be the board itself as the heatsink made of alu leads away alot of heat... it gets hot to say the least, routing a tube from the A/C is a brilliant solution as it also have crossed my mind ;-) you should make that... saves alot of headache later on
what harness cable do you mean your waiting for ??? power between car and computer ???
i think i've heard that wifi-card name before... hmmm better for wardriving or monitoring air packets :P ???
forums in general sucks on showing pics... i'll edit the last post putting links instead as they work
peace and lets me know how things turn out for your setup
Sponsored Links
Old 08-01-2006, 05:17 AM   #11
Nomad's Avatar
Vehicle: 2003 Chevy Silverado
My Photos: (0)
I had a simular problem with the sound plug, it was loose and had a lot of static when playing. I added a USB 2.0 card to the pci slot and now I use usb for sound, gps, wi-fi, ect, all work fine.
VIA EPIA V 1.1ghz
512mb memory
40gig 3.5" HDD
Slim Line DVD/CDRW
80w DC-DC Monex psu (fried 2, working on #3)
8" Datalux TS LCD
Sound Blaster USB
Nomad is offline   Reply With Quote
Old 08-01-2006, 07:16 PM   #12
walstib's Avatar
My Photos: (0)
I found a place that supplies the harness to Clarion for the CD changer I removed. This way I will be able to terminate the carputer (audio) wiring to the harness and then plug the entire unit into the head unit and not have to cut & splice wires. That will help if I ever sell the car. I can put the changer back and it will plug right in. It will also expose the steering wheel controls which I may look at doing something with. Right now, they will control volume and radio on head unit, when PC is selected as input, they will control only volume, so I may be able to use them for fast forward, rewind, etc.
The wifi card has good output (250 mW, I think) and fully spported under Linux with netstumbler, swscanner, etc. for war driving. Hook it up to one of these and I should be set.
Hey Nomad,
The problem is the Nano board has only one slot and it is a miniPCI slot. But there are 4 USB 2.0 ports. I am running my HDD, GPS and touchscreen through USB.
Sponsored Links
vB code is On
Trackbacks are Off
Nano ITX is it worth it?????? gt__1 General Hardware Discussion 29 03-28-2006 12:07 AM
Nano ITX - soon to be available !!! from mini-itx.com SAScooby General MP3Car Discussion 6 02-24-2006 08:37 AM
NANO ITX boards are finally at the mp3car store! god_of_cpu General Hardware Discussion 56 09-12-2005 12:35 PM
sound quality between carputer going through the HU and carputer going to amp lookinco Car Audio 9 08-07-2005 11:27 AM
got sound? masch Newbie 20 11-17-2003 09:01 AM
Sponsored Links
SEO by vBSEO 3.1.0
Ad Management by RedTyger
