Old 07-25-2006, 07:07 PM   #1
koolharshis is on a distinguished road
Power from Headunit?
So i got my carputer assembled...pics will be up shortly. I had a question about the back of the headunit. Basically, i want to take my headunit out (stock 96 lexus naki system) and put the touchscreen there. But before i do that i thought about the sound. When we flip the headunit over, do we have different outputs for each speaker? I want to try and get around trying to power the speakers up from the amp, if they have seperate wires from the headunit, ill take them out and put them in the sound card, but wanted to ask if thats possible. Thanks!
koolharshis is offline   Reply With Quote
Old 07-25-2006, 07:11 PM   #2
MySQL Error
scott_fx's Avatar
scott_fx is on a distinguished road
unless your system has external amps for each speaker you are going to need some external amplification. your soundcard can not power speakers
New System in progress:
M10k
Phaze TD1500 ~> Seas g18rnx/p
Zapco Ref 500.1 ~ 12" tc-9
Transflective Xenarc
My Car Pc Install
scott_fx is offline   Reply With Quote
Old 07-25-2006, 09:32 PM   #3
yes, my system does have an amp, but its under the passenger seat (stock amp-they had to put it in a complicated place to make it harder for me ).
Old 07-27-2006, 12:07 AM   #4
walky_talky20 is on a distinguished road
Here is the radio wiring diagram for a 1996 Lexus SC300 with the Nakamichi Stereo System.
1996LexusNakamichiSystem.pdf
It looks like all you need to do is connect to a couple wires in the radio connector in the dashboard and you're all set. You should be able to figure out which wires to connect by using the diagram.
I wasn't sure what model of Lexus you had. If it's not an SC300 then I can get you the right one, but they are probably the same anyway.
Peace.
walky_talky20 is offline   Reply With Quote
HOW TO:use opus with a laptop...... turbocad6 Power Supplies 24 06-25-2009 07:31 AM
Power supply Problem xGROMx Power Supplies 8 03-16-2007 02:19 PM
Power inverter problem. blackedoutxb Power Supplies 13 11-14-2005 10:51 AM
Low power alarm, kind of System-f Power Supplies 5 03-11-2005 01:48 PM
FS For Sale 7" LCD VGA/USB, Opus 125w Power Supply, ATX P3-700 10GB 256r oudis Classified Archive 7 06-15-2004 10:29 PM
