Old 07-26-2006, 01:31 PM   #1
Charles1's Avatar
Charles1
High pitch noice
Ok i have done everything i can place rca's as far away from the ower wire and so on. Well everytime I turn the car on i get a high pitch noice that goes as long with the gas pedal. the faster I rev the higher it gets. Any info on how to kill it. I tried those rca thing you put on the rca capble it seems it has a magnet or something. Please help its ok during the day but at night it bugs when i listen to the radio at soft levels.
ccortes@smscorp.com
Charles1 is offline   Reply With Quote
Old 07-26-2006, 01:33 PM   #2
evandude's Avatar
evandude is on a distinguished road
you need to provide details of what your setup consists of, if we don't know what you have then it's hard to make suggestions about how to fix the issue.
First question regardless of setup though, is:
do you know what a ground loop is?
But don't take it from me! here's a quote from a real, live newbie:
Quote: Originally Posted by Viscouse
I am learning buttloads just by searching on this forum. I've learned 2 big things so far: 1-it's been done before, and 2-if it hasn't, there is a way to do it.
eegeek.net
evandude is offline   Reply With Quote
Old 07-26-2006, 01:35 PM   #3
MySQL Error
scott_fx's Avatar
scott_fx is on a distinguished road
how did you ground your amps and computer psu?
New System in progress:
M10k
Phaze TD1500 ~> Seas g18rnx/p
Zapco Ref 500.1 ~ 12" tc-9
Transflective Xenarc
My Car Pc Install
scott_fx is offline   Reply With Quote
Old 07-26-2006, 10:19 PM   #4
Charles1's Avatar
Charles1
ok as far as grounding goes. I grounded the amps to the metal where the shocks and bolt to in the rear. I sanded and drilled and used a washer. The car I have a a mitsu eclipse 1995. As far as set up goes I have 1 four channel amp and a mono sub amp. Brand is Ma Audio. The carpc should not matter I am using a laptop.
ccortes@smscorp.com
Old 07-26-2006, 10:27 PM   #5
Shadow is on a distinguished road
Does it make the noise when your laptop's running off of battery power?
Shadow is offline   Reply With Quote
Old 07-26-2006, 11:05 PM   #6
MySQL Error
scott_fx's Avatar
This was my initial impression when you posted the laptop thing. I remember helping a fellow member with diagnosing a similar problem back in the day and it was in fact the way he was powering the laptop
M10k
My Car Pc Install
Old 07-26-2006, 11:21 PM   #7
Charles1's Avatar
Charles1
ok but even when the laptop is not plugeed in the car makes that noice.
ccortes@smscorp.com
Old 07-27-2006, 12:06 AM   #8
MySQL Error
scott_fx's Avatar
just to make sure it's not the problem of the laptop. can you hook up an ipod or discman or some audio device to the amps and see if it still makes the noise
M10k
My Car Pc Install
can a carputer replace a high end av dedicated system? turbocad6 Car Audio 85 07-09-2007 05:44 AM
high pitch sound nguyenpd Car Audio 4 06-28-2006 09:21 AM
fm modulator: high pitch whine mattress Power Supplies 1 03-22-2005 07:46 PM
high pitch coming from TFT LCD r2o4b0sx LCD/Display 2 09-16-2003 05:10 PM
Monitor makes high pitch sound... SuperMatty LCD/Display 5 03-12-2002 05:46 PM
